damn wide body gts-ts. we were without fwd for all of targa except the first day last year - and you relly do notice the difference :blush:
don't worry about the off-track excursions - if you don't go over the edge how will you ever know where it is???/
OH MY GOD! OH MY GOD! I GOT SPOTTED :PBJ:
Thanks man :D wanna buy it :thumbsup:
I think it was a bit of both (lag and double demerits)
I saw the plates and figured it was you slim, nice car dude.
haha thanks mate :)
I want your bonnet :) But I'm trying to sell mine at the moment so yeah dont need yours too haha
I would have put down my passengers window to say some thing, but it doesnt work...so I wasn't being rude :)
on the weekend i spotted a bayside blue r34 gtr with vented bonnet (small triangle vent to one side...) is this a v-spec? in the car park at castle hill shops on victoria ave where good guys is.
spotted another R34 GTR (silver) on the back of a flat top at castle hill (near towers)
spotted HCR-32M (i think) dark colour R32 in beaumont hills on brampton dr, and also spotted a silver R33 just behind it.
spotted a silver stag some where too lol
Edited by Black Widow
No it means that its a V-Spec 2 bonnet!!
So yeah
Spotted a silver 32 GTR yesterday around lunch time on epping road lane cove west and spotted js 2000 in the morning on the same day in lane cove business park.. WHOOOO ARE YOU!! I KNOW YOU ARE A CLUB MEMBER!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
