Spotted a grey R32 four-door parked at a servo kinda half-way between where the Krispy Kreme/Harry's/Megacentre and the intersection of Cumberland and Hume Highways meet.
Spotted EXH-45T near Warrawee
And LI-22-EH in the same place.. Honked when I went past Liz but I bet you had no idea who I was.
you were in a pulsar, yes?
spotted LI22EH parked on the street... anyone want some rims? :P
oh sup
spotted duncan this morning on beecroft road or something.. i didn't wave incase he banned me.
I don't know much about Stagea's but there is always one parked out the back of Mitre 10 in Wentworthville, white with gold rims, anyone on here?
Spotted a silver stagea today at towers roof carpark "BEO..."
Post these in the Stagea spotted section, we might get some answers! There's a link in my sig, too...
I might have to go and check this one in Wenty out, though, it's not far from home. Did you get the plates, SL33KY?
Yep. White n14 with a pushed in rear end hahah.
Today spotted a white R33 GTR near Chatswood.
Also spotted a blue R32 GTST or GTR parked at BP near the airport, big chrome impuls.. looked really clean from a distance.
Hey anth... hahaha thanks for the work man.. it was worth it.. spewing though about the 4th run i was looking forward for a better time...
PS: guys i recommend Anthony at Dahtone racing for good value for money and reliable performance work :thumbsup:
shit box civics that blow up and spill oil all over the track should be crushed
tell me about it.. i dont get why they are allowed to run man, they ruin it for everyone..
PS: also spotted anths sex machine 2GU UP man ur car sounds sex.. love that screamer
