Spotted two Skylines in the space of 100metres and less than 5 seconds - one was a silver R33 GTSt reversing out of a driveway on Fitzwilliam Rd in Toongabbie, and the other was a black R32 GTSt turning left off Fitzwilliam Rd and into Tucks Rd.
Spotted 2 nice white R33s within about 2 minutes of each other at 11:45am travelling down Roberts rd near punchbowl, greenacre. 1 waiting to turn onto Roberts, either a GTR or trust front bar and GTR wing and the 2nd heading towards Hurstville way, GTR wing with a black blade and what looked to be a trial rear bar. Nice cars if you're on here. :D
You should have stopped and found out! :P
You should always look after fellow import owners, especially if they're in the same car as you :action-smiley-069:
I think that might be e-dog on here too, not certain though...
It wasn't that easy. I was in the far right lane, in heavy traffic, and I spotted him pulling into the hard shoulder on the far left just as I was driving past. Not the easiest thing to get over three lanes into the shoulder and pull up during in peak hour.
iam a truckie, i work down in canberra and spotted R33 GTR BCNR33 plates i think it was.. white one
then also an R34 GTR as well as the powerplay imports nissan navara ute
following soon after on the hume highway heading towards canberra..
round 7.00 last nite
very nice looking cars, must have been heading to wakefield or sumfing
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
