Spotted a lovely Silver R32 GTR today along Mona Vale Road just before St Ives. Had an SAU sticker on the rear side window. Fairly dirty at the rear end of the car. Number plate was 'AQ 92 ZI'. The guy driving it was very conservative, good driving :( If he's online here I was in a white Peugeot 206 just near the petrol station at St Ives shops.
Peace
Spotted a very mean looking R32 GTR looking wider and cleaner than before at chatswood blinding me with HIDS, Looks nice - Real nice.
Also spotted and waved to a silver? R33 in chatswood - At least I think it was .. HAD SAU Sticker on it..
Nice to cya!
spotted a red R34 GT-t last night at a servo on old windsor rd last night..had R32 stockies..looked nice
and last week spotted:
silver 32 4 door in artarmon...plates were DOR-132
Silver R32 with chromes on windsor rd..can't remember what day
gunmetal 33 on quakers park way
silver 33 AWS-94X in artarmon
Orange R33 on Pennant Hills Rd exit off Cumberland Highway
White R33 on JRD
White R33 in norwest WGH05T
Spotted OSAKA shooting through anderson st chatswood, Car sounded mean in the westfields overpass.
Looks great with stock suspension lol
Just a tip Loz, cops are now defecting or "fining for minor traffic offences" as they put it under that overpass. Thursdays mostly (night)
Edited by DECIM8
last night spotted a silver 32 GTR on windsor rd, plates were GTR-***, and spotted a bayside blue R34 GTR that had a big Top Secret Imports sticker along the side on samantha riley drive
Awesome looking R32 GTR this morning in gunmetal grey. It passed next to me on Beecroft Rd near Cheltenham Girls School. Had big bronze rims, possibly TE37s, with lovely offset. It also had this big 'SKYLINE' decal in the back window that I've never seen before. It looked like it could've been part of a factory window tint or something? Interesting.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
