Spotted an orange R33 plates were ITSFUN i think on epping road near Macquarie.
Black R33 on Epping road near M2/Lane Cove Tunnel - standard plates - possibly 400R front bar
Gunmetal R32 parked in St Leonards on Herbert St - standard plates
this morning between 7:30 - 8am
Yeah i didn't think it was standard plates... umm must be a really good double.
does this doubles power windows work properly???? if so (quick albert, i distract him you get the window mechanisms)
spotted either Sheng or a total look a like at carlingford court leaving tonight round 6 ish... i was the one starring in the blue shirt. number plate bb something?
That would of been me.. black r34 4 door with black drifteks.. number plate bbx.. sorry dude didnt see ya looking.. lol where abouts were u?
not a skyline but an interesting spot,
spotted a silver 300zx on Aiken road at west pennant hills today parked on the side of the road, Number plate was "FSTLIN". and no it wasn't 4styln, stock standard outside.
Hey, sorry nah is was a coupe not a four door but glad to know theres more about in the area.. i only seem to see the non turbo ones.
spotted white r33 at ctown road just over the bridge turning to queen street this morning and always spots a silver r33 at ctown rsl club carpark.... damn and 2 stagea but seems that theyre not members or even forum members :D
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
