Spotted:
- White 34 on memorial ave
- Think it was a gunmetal 32 on sunnyholt..SP00LZ??
- Candy red R33 in Blacktown, plates NICEAY
- and another (possibly same as before) white 34 on sunnyholt about 9pm
Yeh my baby VRR-55H haha lol :D yeh white R33 with black/Carbon Fibre bonnet, are you the black or grey 32?
i was in the black 32
spotted white r33 on the hume this arvo, cant remember plates tho
Edited by roadworia
Spotted at about 4:45pm on Pennant Hills Rd a bright blue R33 with GTR wing, looking all banged up, front bar broken and dragging on the road, front and rear quarter smashed in, hope you weren't being silly in the wet weather and lost control!
Spotted Today (14.2.09) candy apple red R32 at 9:30am turning up on to blaxland rd campbelltown being a complete f**king tool
I think spotted the same R32 this morning at Raby road St andrews driving with a phone and man turning into a runabout like hell
Wasn't yours was it :P
spotted:
-gunmetal grey r33 at george st - hawkesbury valley way lights in windsor (ffs someone join sau from out this way no one ever picks these spotted's up!)
-white r32 next to west ryde hotel today round 2.30ish
i stopped at the lights right next to both you guys...in the black 33 with the stupid bonnet.
Spotted GTR R4 with asian driver at P6 and other Skylines i think none SAUer? anyway if you guys are here we are the last group of skylines came to P6 we are late lol :) im driving the shit looking shit box white R33 with GT wing and carbon fibre bonnet
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
