spotted white r33 gtr at macquarie shopping GET53T
I see GET53T almost every morning doing the commute from Rydalmere area over to the hills area :laugh: I do the same sort of commute but in reverse... so no im not a stalker LOL
I see GET53T almost every morning doing the commute from Rydalmere area over to the hills area :rofl: I do the same sort of commute but in reverse... so no im not a stalker LOL
when i used to goto uni early for study during exam period i used to see it everyday driving along the same road
"CYIFLY" tonight 10pm cnr Hume Hwy & Gt Western Hwy Summer Hill.
Got beaten by a Camry over two metres; till his reflexes kicked in...lolz
White R34 GT-R with black bonnet. Looks like...
