spotted a white 4 door R34 GT-t in Avoca beach on Sunday
also spotted a black 33 XTC25T yesterday somewhere..can't remember where i was..somewhere in the hills area lol
Edited by Black Widow
ooh that would've grinded my gears,
you know what's a similar feeling...
I'm a guitarist, and it really sh$ts me when I see actors on the telly pretending to play while they lay over a recording and when the show takes it further, tries to make look "real" by making them move their hands up and down :whistling:
It's NOT a FARKIN GTR and THEY'RE NOT really playing!!! :D:):no:
or when they play piano they never show the hands :D
or when they fly a spaceship and they dont actually know how to
or when they....
I think it's called acting guys :)
it's a completely different thing mang :/ , how many people do you know own and operate a spaceship?
but yeah a small thing but still bugs me
it's a completely different thing mang :) , how many people do you know own and operate a spaceship?
I used to, but constantly travelling through the space-time continuum plays major havoc on your body, so I gave it up, sold the spaceship, bought a Stagea, and have more fun with less body-clock issues!
Spotted a maroon R32 GTR on Old Windsor Road heading towards Rouse Hill. Had an SAU sticker in the rear quarter window, and was bellowing black smoke out the back.
Spotted your Blue? supra, nice car.
Ha ha that was me, running rich on boost and the clutch was dying, so revs were going up, speedo wasn't lol!
Yeah, that was me. Thanks!
I was sitting there telling my missus that there was something wrong with it, on top of running stupidly rich. She just thought it was a shitbox. Sigh.. Women.
Yeah my missus thinks that tuned cars (not kingswoods) that blow black smoke are shitboxes about to blow up. She tried to get me to buy a micra (shivers down spine). Over my dead body.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
