hey Nick, when you say GT-R coming soon...its not the Lancer GT-R right? wehehe Jk.
so what if it is?
The Lancer GT-R is the corner stone of the JDM scene, and should be recognised.
lol..
it almost look like the done up cars in the Philippines. =)
i swear i saw a couple of them last time i visited. They love the multiple mirrors there. specially the beloved Jeepneys below! :P
so..i spotted this Mitsubishi Lancer GT-R with dual mirrors on each side, dual exhaust left and right, custom kits (mini bullbar at the rear) and custom vinyls. spotted at Blacktown Westfields. :P Oh and that black stripe to break the line is duct-tape.
Poor Lancer!
spotted KNG GTR on windsor road this morning (black r33 gtr). I putted pasted you in a yellow dc2 itr. you on here?
I saw that car in thornliegh a while ago, sounded very tuff! and not to mention it looks very nice too
so..i spotted this Mitsubishi Lancer GT-R with dual mirrors on each side, dual exhaust left and right, custom kits (mini bullbar at the rear) and custom vinyls. spotted at Blacktown Westfields. :cheers: Oh and that black stripe to break the line is duct-tape.
Now we know where to link the new kids looking for a cheap gtr to.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
