mine! haha never been in this thread and thought i take a look, and ive been spotted :D
spotted you on monday going through the marrickville rd/wardell rd intersection, was with the ms's in the excel and i beeped like a madman :P
Hope they both loose their cars
Off topic; There's a lot of venom there; Do you know the exact circumstances of this incident? I'd have hoped a fellow enthusiast might give the benefit of the doubt.
I hope you have NEVER pulled away hard from a set of lights with a car next to you.:rolleyes:
Yes, because a *squirt on the street* is soooo much more dangerous than high range PCA; and you don't lose your car for that...:whistling:
*NOTE* I do not condone street racing, there is a time & place (take it to the track) but confiscating cars should either apply to all vehicular criminal behaviour; or none at all...
DUI driving is a menace, and FAR more dangerous but the confiscation rule doesn't apply. WHY?
Don't be a hypocrite; all or nothing.
Edited by Daleo
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
