Nope wasn't me.
There's been another white 33 driving through Robbo a lot lately.
Also.
Must've been some cruise on, spotted a bunch of cars;
Yellow S15
Red S15
White 32 (most likely a GT-R)
White 34
Black Evo 6
Some WRX's
And 2 more R32s of various colours (was soooooo many business didn't have time to compute WTF was going on.
May have seen me going back and forward. Got rid of the 2DAMQK plates. Sick of being pulled over by the popo all the friggin time,
Yeah I noticed that.
Theres a guy in Robbo with a S2 33 in pearl white with black rims.
He's trying to sell it but he drives it around every now and then.
Might've been him you spotted.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
