Franks...i spotted your car on parra road on friday nite at like 1am turning right towards burwood. I didnt recognise the plates..but i recognise your car and your face from the SAU fotos. I was in the White s2 r33 at the lights next to the Quix? petrol station! You got a very nice car dude.! i seen pictures of it..but seeing it in person...very very nice ride u got there..im very jealous hahah
went to huntley's hill climb today down at dapto, wollongong.
spotted a yellow lamboghini gullardo, and a hacked up bnr32. the rest of the cars were clubmans, open wheelers, 1 wrx, lots of done up race car gemini's, torana's, and beetles!
god damn it!
Spotted: 1 x concerned female passenger on EC Skidpan figure 8 ;)
LOL!!! are you talking about me?!!?!? hehe...i wasn't concerned! though i was hanging on for dear life! that was soo amazing!! don't think i could do something like that...but i'll still give it a go! :) Was going to hang out for a little longer, but the top fuelers at EC distracted me!!! ;) How did the rest of your day turn out?
Let me know when you organise the next one!!!! :P:(:D
yeah man... i finish at 7 .. so i have been spotted?!
WOOHOO!!
you at work slim?
yeh mate at work about to go home I think
hahahaha...are you chris' mate?  The one that came down to say hi? hehehe... hes got you hooked on the forums hey? :P
Teletechs too easy a pitstop on the way home! :D
I'm chris mate but not the one who came down whoever that was :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
