Spotted r34 with nsw plates cant rember exactly stopped at the lights of the highway in my home town of WAGGA WAGGA i nearly shit myself an r34 in wagga if i wasnt half pissed at the time would have trie to get the bloke to stop and chat, i reckon he would thought i was trying to mug him if i did. does this mean i can call wagga a real city now we have an r34??
haha id say 90% of wagga wouldnt know what it was, i now i was with a big group of people last night and only one of knew what it was, the rest were like whats so good about that??
thats a punishable offence isnt it?
I saw GTS70Y as well yesterday. Very clean :(
I also saw a nice GTR in Neutral Bay last night. Didn't catch the plates though.
Hey,
Im suprised it was clean :) i havn't washed it in 2 weeks (very rare for me :))
what car were you driving? i have seen a fiew lately.
Ash.
