spotted liz in the siliva going for a run down the old pac yesterday. i think it was u cos they beep when i was at the truck stop.
sure was!!!!!!
Christmas Cruise..
bummer, I missed out!
ps. your car looks nice dude, we saw it parked on the side of the road!
enrique! You should really stop stalking me you know!
sure was!!!!!!
lol, i saw your silvia, looks clean :(
was i near the car when you drove past?
bloody hell I spotted 41 skylines at Fagan park. was something on?
Bunch of bloody hoons, they are, these Skyline drivers...
Get a Volvo!
(A Nissan "Volvo," that is!) :(
LOTI!!!!!!!!!!!!!!!!!!!!!!!
hahahahaha
LOTI always results in a LOL
lol, i saw your silvia, looks clean :D
cheers! I :P it. hahah clean apart from all the unburnt fuel on the rear bar. Please no one smoke near my car lol.
nah you weren't!! It was just parked out front
Spotted Corinne (D_I_F) on old northern today, she pulled over and lent me a hand... Thanks for that... Love that car :thanks:.. have fun for the rest of your cruise :P
OMG! Ive finally been spotted!!!!!!! NO WAY! haha..
Lucky you were alright :D
Cool. Few people know that I actually grew up ON Fagan Park. My old man was the caretaker. Ahhh, the memories of having a 140acre backyard and a trail bike. Noice
Hahahaha! FAGan Park.
i wouldn't tell many people either
Guest
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
