  • Replies 88
well if yu have heap of competition i reckon if yu start out cheap and raise it when yu start getting good buisiness your name will certainly be getting around ...
its the same thing with spray painters aswell but thats jus imo
jon,
ta.
Chris,
they want 18,700 for it and thats probably where it will stay( IE no neg.). I have yet to look inside but it does see some street traffic and its plain enough for me.size is 220m2 if I wanted the lot (and $33k!) or 120m2 if I take the front. routing traffic from the south will be fun but doable. northside stuff and referrals I do not see being an issue.
as fro changes - yep! not a lot of riff raff there now. figured this would be easier than trying to route work to further north and losing it.
we'll see as its all open for discussion currently.
Sara,
been doing this for 21 yrs the last 11 have been here in brisbane. most of these guys know me /my work quite well. do a bit of a search on this site/boostcruising/nissan silvia and quite a few others for the business name. (or toss it into google for australia only.) I also sponsor the Qld skyline club. google by itself should yield a few things.
you get what you pay for chris is worth all the money he charges speciallly us v35 owners wouldnt know where to start without him saying that other audio mobs wont come close to his work..
[quote
Sara,
good i hope all works out :D
Right near good coffee outlets too Chris... :)
haha, yep got to agree on that one!
time for another one mate!
Chris, have u moved house?
this would be handy to yr place at WH
with the upgrades/development of the airport area, I'm told this will spill over to surrounding areas, incl Nundah - prices will only go up! good luck mate!
thats what I'm hoping for. yet to move house.
this thing is huge!
looked at it today and there is a retail area off to the right side of the door and plenty of room to hold 2-3 cars easily in there.
I can see this working. I'm doing numbers on it now and so far looks good.
nundah is a no go. solar company got it. (I'll wait for the gov't to can the rebate scheme. I want that spot.) so the search continues. brendale anyone ??
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
