  • Replies 61
^^ Brids, he already has a FMIC and turbo back exhaust. :)
Boost controller is the next step then maybe a tune, get an APEXi Power FC...
Upgrade your Panel Air Filter to a high flow one, like APEXi, K&N just to name a few... Or you got an air pod?
I never new the Crossfires where that fast...
mate i got a HKS pod filter, seriously bro dont know anything about crossfires its just one of my
friends he has an r34 and his girlfriend just bought a crossfire he drove it and said they are good.
thats y i was a bit concerned.Getting a manual boost control next week, Powers FC is next on the list
its just ma pocket is holding me back this month, was looking for a second hand over here but can seem to find 1 for a good price
still searching
powerfc, injectors, gt35 internal gate, exhaust manifold spacer, z32 afm, 22psi boost.
gogogoog
why just beat him when you can completely annihilate him
Agreed.Thats what am gona do still have time ill put all the godies in my line and then take him to Calder
What he just mentioned is about 5 GRAND or more worth of gear.... not to mention clutch and tyres etcc...
u'd be getting close to $10,000 ...
so at the end of the day...is it worth it?
just asking(and assuming)...do u have a small package or something and need to show ur a man?
u've got the basic stuff... buy a $50 manual boost controller and get some more boost... if he wins hes no better or worse a bloke then you...
just remember that when your laptop says "danger to manifold"
SLAM it shut and tell it to shut up!
you'll run 10's
srsly tho.... crossfires are slow as... a 33 with basic mods will munch it
thats not a thing mate i respect all racers its just if some challenges you u cant step back :thumbsup:.
i boutght the car 2 months back i got it for just one reason ill maki it a fast gtst.cant do it all at once but the guy challeged me at the wron time but still have to keep
upto mark :)
Rent my car for the race. Its being Scoutered to have a power level of over 9000!!!!
Also comes with a different buttons for different stages of turbo boost transformation to boost the power further from 9,000+ to 12,000 to 18,000 to 21,000 to 24,000+
Crossfire have a 0 to 100 time of ~8 or something?
Edited by Mayuri Krab
you'll run 10's
ur right bro its just didnt wana munth it want to swallow it :).so have to do a bit uv mods. :thumbsup:
You are correct my brother man. It is just that I did not want to simply masticate said crossfire, but digest it entirely. I do believe I will require modifications to my automobile.
huh?
:thumbsup:
Check this out. It will give u ideas
(POSITIVE)
0 to 100 6.5sec
It can reach 150+ MILE flat. 250kph
Check this one out (NEGATIVE)
Top gear
Well i reckon u can beat it if u know how to launch it!
Edited by tavstar34
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
