  • Replies 61
^^ Brids, he already has a FMIC and turbo back exhaust. :)
Boost controller is the next step then maybe a tune, get an APEXi Power FC...
Upgrade your Panel Air Filter to a high flow one, like APEXi, K&N just to name a few... Or you got an air pod?
I never new the Crossfires where that fast...
mate i got a HKS pod filter, seriously bro dont know anything about crossfires its just one of my
friends he has an r34 and his girlfriend just bought a crossfire he drove it and said they are good.
thats y i was a bit concerned.Getting a manual boost control next week, Powers FC is next on the list
its just ma pocket is holding me back this month, was looking for a second hand over here but can seem to find 1 for a good price
still searching
powerfc, injectors, gt35 internal gate, exhaust manifold spacer, z32 afm, 22psi boost.
gogogoog
why just beat him when you can completely annihilate him
Agreed.Thats what am gona do still have time ill put all the godies in my line and then take him to Calder
What he just mentioned is about 5 GRAND or more worth of gear.... not to mention clutch and tyres etcc...
u'd be getting close to $10,000 ...
so at the end of the day...is it worth it?
just asking(and assuming)...do u have a small package or something and need to show ur a man?
u've got the basic stuff... buy a $50 manual boost controller and get some more boost... if he wins hes no better or worse a bloke then you...
just remember that when your laptop says "danger to manifold"
SLAM it shut and tell it to shut up!
you'll run 10's
srsly tho.... crossfires are slow as... a 33 with basic mods will munch it
thats not a thing mate i respect all racers its just if some challenges you u cant step back :thumbsup:.
i boutght the car 2 months back i got it for just one reason ill maki it a fast gtst.cant do it all at once but the guy challeged me at the wron time but still have to keep
upto mark :)
Rent my car for the race. Its being Scoutered to have a power level of over 9000!!!!
Also comes with a different buttons for different stages of turbo boost transformation to boost the power further from 9,000+ to 12,000 to 18,000 to 21,000 to 24,000+
Crossfire have a 0 to 100 time of ~8 or something?
Edited by Mayuri Krab
you'll run 10's
ur right bro its just didnt wana munth it want to swallow it :).so have to do a bit uv mods. :thumbsup:
You are correct my brother man. It is just that I did not want to simply masticate said crossfire, but digest it entirely. I do believe I will require modifications to my automobile.
huh?
:thumbsup:
Check this out. It will give u ideas
(POSITIVE)
0 to 100 6.5sec
It can reach 150+ MILE flat. 250kph
Check this one out (NEGATIVE)
Top gear
Well i reckon u can beat it if u know how to launch it!
Edited by tavstar34
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
