Im thinking of buying a set of 18x8.5 volk TE37's for my series 2 C34 and i just want to see if i like them on a stagea before i get them cause its a lot of money and im pretty picky when it comes to rims.
So i guess im asking if anyone has any pics of a stagea with TE37's preferably series 2 but i guess any C34 would do, Can you help me out?
Thanks
Stu
https://www.sau.com.au/forums/topic/294619-series-2-with-18inch-volk-te37s/
18x9+20(might be +22) would fit better IMO... you can try my GTR rims on with a 10mm spacer if i can find it for guard clearance, and being x9+20/22 would make it GTR offset and more common to find and resell.
My 2c
Is your Stagea a RSfourS or auto converted?
If Rsfour S - you'll need at least +20 with 8.5', +15 with 9-9.5' rim to clear rear strut!
If auto - +30 offset all round
I run 18x9.5 +15 all round with good fitment/clearance on RS4S.
What he said.
The 8.5 will need a fairly wide offset to fill the gaurds on the rear of a manual plus for the te37 to look any good they need some dish on the spokes
The first pic of the silver car has no dish and the spokes are vertical. Does not look good
Second pic has a fair bit and looks good
I would try for some 18x9.5 +15 or +12
On my Rs4s I ran R34 GTR wheels which are 18 x 9 +30 and they fit fine.
ok. te37's
HOT wheels in the right specs but look farking terrible in the wrong ones
you need a decent width and low offset to get the concaved spokes
step up to 19's and you also get some slight dish (for lack of a better word)
but 18x9.5+12 all round will be nice, it will be aggressive but the only way i'd run them personally :P
if you are going to opt for a weak offset in 8.5's you may as well get the temp copy of the wheel. it will be a dickload cheaper. and i'm sure you won't notice the extra few kilograms in weight difference in stop start traffic
I have TE37's in 17 on mine, they are brilliant wheels and some of the lightest in the world, I was lucky enough to have them delivered with the car from Japan. However, as everyone has mentioned the offset needs to be right to get the awesome concave 'JDM' look that everyone loves. Unfortunately mine are low offset, i.e.: no concavity, and as much as I love the wheels it has always bothered me as they don't look aggressive enough on the car. Being 17's on a Stagea they also don't fill the huge wheel arches we all have enough.
If you look at the prices between wheels on any of the Jap import sites (Nengun, Perfect Run, Greenline etc.) the price difference between a no offset 17" and a high offset 18" wheel is around AUD$150 a wheel, so my advice would be get the offset and size perfect for your taste as the price difference is not shocking.
TE37's are hugely expensive comparatively to other wheels, so the other option if they become too expensive is ROTA Grids, massively popular in the US. Obviously not up to the quality standards of the TE37's, and not to my personal taste, but they are pretty much exact replicas (Visually) and can be delivered in 18 x 9.5 or 18 x 10 with huge offsets and 20mm to 35mm of dish for around US$1350 delivered, or just under AUD$1500.
My wheels were originally Bronze, but I am having them resprayed Satin Black as we speak to match the new exterior mods, I will post up pictures of both colourways when I get my car back... whenever that will be :P
harts.
your wheels are high offset :P
and don't get me started on rotas haha
oh what the hell
before
after
etc.
please don't buy rota lol
Ha ha! I can assure you, as soon as it is ready you guys will know about it. It has been a looong process! I did find out that the wheels have been finished in the Satin Black and are back on the car. Car is now off stands and the rest of the bodywork has begun. As Chris said we are going to have a look at it next thursday, I'll take pics of the wheels.
Back on topic though (Or not)... I want to see more pics of broken Rotas! They are great ;) Epic Fail FTW!!
harts.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
