Brought this a looooong while back an finally am getting my "built" Motor in an wondering now if I wanna risk using it or not
Looking to get opinions
According to the guy I brought it off it had been flow tested an addressed nicely the flow problems inherent with the stock manifold
was claimed to be off a big big horsepower rb26
Has been ceramic coated and has had a 1/8th bsp hole added ,I assume for a maf sensor or something
Will just block that off with a plug as am planning on using AFM's assuming a standard brass plug orta hold okay
connection to cooler has been opened up to 4 inch so will need a 3.5 to 4 inch silicon reducer there
Am thinking I will try it out an see but wondering if anyone has any opinions or even better recognizes it??
Sadly I didnt get results of flow testing when purchased an as far as I know no one in Darwin has a flowbench capable of testing it
https://www.sau.com.au/forums/topic/294743-modified-rb26dett-intake-manifold/
Looks good to me. Flow test it to find out. Ideally you should run an Intercooler with a 4" exit and run 4" all the way.
Also the mine's car doesn't run a stocker, it runs a nismo. You can even see where the nismo badge should be in the engine bay shots and they just put a Mine's badge in it's place (just like the "Mine's" Mafs)
Just a thought but where it has been modified at the rear are you going to run into clearance issues with the clutch master cylinder?
Any reason you need this over the std plenum? I have the std one on mine and it works fine at just under 400rwkw, the enlarged opening will kill off some of the response but it really depends on what you are after.
Dont think clearance will be an issue, touch wood!
"Need this" na not really I spose but
figured with the ceramic coating and potential for extra flow
it wouldnt hurt ????????
And as stated dont believe I can flow test it without sending it down south
figure I could try it then possibly replace quicker than that!
Edited by noone
Beigh that the problem with the stocker is too much flow and pressure banking up to the rear cylinder, i would think the modded one will be worse. Flow testing it wont really tell you much, only logging the individual cylinders afr/egt's will give the answer.
Hey noone can you elaborate a little further on the inherant flow problems of the stock plenum ???. Mate there are far to many GTR's with
400-450 AWKW including my own car and several others I have built all running the stnd plenum and it is definatly not a restriction. I would also recomend having it flow tested as I am sure it would not be to expensive to have the plenum shipped to a major city to have the the flow testing done. Just dont forget that there is a lot more to plenum design than just the size of the thing and i will garantee that the nismo design will definatly be a better design than a modified stnd design regardless of the size of the thing.
Appreciate that and yeah makes sence since the rear two tend to run lean
thinking the step from 3.5 inch to 4 may help with this added turbulence et all
may be better sticking to the stocker but would wanna send it to ceramic coat, meaning more waiting?
logging individual pots would be nice other than heat gun on the dyno probly not easy though
and have ceramic coated the exhaust manifold to so may not show much??
yeah I was more thinking the rear two cylinders running leaner et all
but as stated this probly would make that worse??
despite even flow on a flowbench etc
Ya can definitly make good power with the stocker wont argue that !!!!
I am starting to think it may be wasted cash????
Edited by noone
Ya maybe but I cant help thinking it may be worth a try despite it bein kinda awkward to change out once in the car
think maybe the slightly expanded plenum size is worth it
I guess other than back to back testing it really would be hard to say?
Edited by noone
i run individual egts in each exhuast manifold runner and cylinders 5 and 6 are not the hottest by a longshot on boost, only offboost, so i doubt very much they are the leanest. Im talking a 50 degree + in other cylinders compared to 5 and 6. This is with a stock 26 plenum and between 420 and 450rwkw. This is the same results on a friends car running a different turbo setup and motor combo but also stock plenum. I think this cylinder 6 is the leanest isnt indeed true when on boost, im sure when u let it idle down the plugs will show it is but thats because it is then not on boost.
thats my 2c worth from real world testing not internet hearsay.
^^ agreed i swapped to the greddy plenum for a few reasons,hp was not one of them, contrary to the thought that 4" would be a backwards step Ive found no difference in "throttle lag" over the stocky.
Here are the latest cylinder balances done via egt for the greddy plenum @ 22psi. (430rwkw 630nm)
Edited by URAS
Thanks for the input there guys, much appreciated!!
You seem to have some extremely cool tuning tools, EGT sensors are tapped to the runners?
would love to see some pics (big ask I know)
very interesting to here thoughts on response not being adversly effected,
Am trying out the gizzmo thermal gaskets too u guys are using them to yeah Trent?
Was planning on giving em a coat of hylomar to help sealing, would this be recomended?
Figure that plus ceramic coating of plenum gotta be worthwhile?
i run the gizzmo gaskets on all builds nowadays, i use ultra grey on both sides abeit very minimal so it cant be seen once assembled.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
