New combo came up nicely, for only 18psi, i expect to see boost come in around 200rpm earlier on the final tune and at least 420-430rwkw. We have gained 50NM of torque from 5500rpm onwards. Unfortunatly the dyno shot i posted rolls over @ 7400rpm but it hit my next load point and dropped into my safety zone of 10.5:1 afr. The final runs actually ran strong all the way to 8800rpm and the last run made over 600nm from 5500rpm but the graph is incomplete so ive left it off. Car should go back on the dyno in a week or so.
Blitz K5-660R turbo #9 rear (0.73ish)
New R34 crank, grub screwed
ATi 1000hp balancer
King bearings
Ferrea 1mm oversize valves in and ex.
Ferrea Titanium retainers and collets
Ferrea Double valve springs
Ferrea Spring locators
New Genuine buckets and shims
New guides
Greddy pro cams 264 9.7mm lift cams (babies)
Greddy pistons
Total seal rings
H-beam rods
ARP head,main and cam cap bolts.
King bearings
Greddy oil pump
MLS head gasket
Status Oil restrictor kit
Greddy Plenum
Greddy 100mm cooler
Saber 12 row oil cooler (blue type)
Greddy Type R BOV... i know dark side, will used for later 2bar tests.
High capacity sump
Edited by URAS
toit! like a toiger.
very good mate. It really is a good set-up.
now I need an answer that's a bit OT. I'm about to put the greddy easy cams into the SR, 256/264 10.5/10.5 but should I bother fitting cam gears too? I think you said not to bother getting any with the current set-up. but someone else now tells me he reckons there is 20kw in it on an SR with small-ish cams by adjusting the gears. I know my experience from RBs tells me sometimes there is (GTR with stock cams) and sometimes there isn't (other GTR set-ups).
not a chance, seriously spend it on hookers and crack.... haha na there is no missing 20 with these cams and the T518Z unlike the BC gear which is ground up to 12 degrees out and need the gears just to dial them in @ zero :D
engines coming out to do back to back testing on combustion chamber mods (quench chamber removal) so next week we will have definitive data on its merits.
Edited by URAS
Are you still planning on painting the car one color or is cat going to be running DA in it next year?
yeah soon it will be repainted, we have a corporate ride day set up at sandown in a fortnight so after that we will get it back up to scratch in new shop colours.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
