New combo came up nicely, for only 18psi, i expect to see boost come in around 200rpm earlier on the final tune and at least 420-430rwkw. We have gained 50NM of torque from 5500rpm onwards. Unfortunatly the dyno shot i posted rolls over @ 7400rpm but it hit my next load point and dropped into my safety zone of 10.5:1 afr. The final runs actually ran strong all the way to 8800rpm and the last run made over 600nm from 5500rpm but the graph is incomplete so ive left it off. Car should go back on the dyno in a week or so.
Blitz K5-660R turbo #9 rear (0.73ish)
New R34 crank, grub screwed
ATi 1000hp balancer
King bearings
Ferrea 1mm oversize valves in and ex.
Ferrea Titanium retainers and collets
Ferrea Double valve springs
Ferrea Spring locators
New Genuine buckets and shims
New guides
Greddy pro cams 264 9.7mm lift cams (babies)
Greddy pistons
Total seal rings
H-beam rods
ARP head,main and cam cap bolts.
King bearings
Greddy oil pump
MLS head gasket
Status Oil restrictor kit
Greddy Plenum
Greddy 100mm cooler
Saber 12 row oil cooler (blue type)
Greddy Type R BOV... i know dark side, will used for later 2bar tests.
High capacity sump
Edited by URAS
toit! like a toiger.
very good mate. It really is a good set-up.
now I need an answer that's a bit OT. I'm about to put the greddy easy cams into the SR, 256/264 10.5/10.5 but should I bother fitting cam gears too? I think you said not to bother getting any with the current set-up. but someone else now tells me he reckons there is 20kw in it on an SR with small-ish cams by adjusting the gears. I know my experience from RBs tells me sometimes there is (GTR with stock cams) and sometimes there isn't (other GTR set-ups).
not a chance, seriously spend it on hookers and crack.... haha na there is no missing 20 with these cams and the T518Z unlike the BC gear which is ground up to 12 degrees out and need the gears just to dial them in @ zero :D
engines coming out to do back to back testing on combustion chamber mods (quench chamber removal) so next week we will have definitive data on its merits.
Edited by URAS
Are you still planning on painting the car one color or is cat going to be running DA in it next year?
yeah soon it will be repainted, we have a corporate ride day set up at sandown in a fortnight so after that we will get it back up to scratch in new shop colours.
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
