alright guys im halfway through changin the clutch in my r32 gtst,
its pretty standard just the usual fmic, exhuast, vg30 turbo and pof filter.
i bought a second hand flywheel and had it machined so i woudlnt have to bother getting it done with the one in my car i could just swap,
however i just took the box and old clutch out and the flywheel in there is a lightened one, by that i mean it has a hole bunch of large holes drilled into it around the edge,
whats the benefits of a lighterflywheel, should i keep this flywheel (if i did i would go and get it machined of course coz its very glazed)
or should i just chuck the standard one in?
thanks
-Alex
https://www.sau.com.au/forums/topic/295036-lightened-flywheel-or-not/
The holes are to balance the flywheel (similar to balancing a wheel/tyre by adding wheel weights, on flywheels they subtract weight by drilling holes). It may not necessarily be lighter - you should weigh them both to check.
The advantage, I believe, is a slightly better acceleration - less mass to be made to spin. The downside can be a poor / unstable idle, due to a lack of rotating mass the help keep the engine spinning.
i was told by a gtr guru that the best flywheel is the factory one vs a/m lightened one.
get the stock one balanced and lightened (i think it drops from 12kg to 8 or 9kg) as it has a better surface and provides better grip and handles more heat than a lightened billet one.
a lighter flywheel will make the car rev quicker.. which is a good thing on the rb20... but it will affect idle a little bit... not much though.. and it will affect the cars engine braking ability and low down driveabilty as in under 2000rpm.
if youve ridden a motocross bike and a big trail bike.. you'll see the difference. motocross bikes have little to no flywheels. trail bike is happy to lumber along at low revs, and can almost come to a stop before stalling.. motocross bike will stall at the drop of a hat if you arent on the gas, but will rev like mad.
Not a fan of lightened flywheels in turbocharged vehicles. They reduce the drivability even moreso. Better off sticking with the standard part IMO, this is a better modification for N/A vehicles.
Depends how light it is compared to the factory counterpart, but with a lightened flywheel you have the abovementioned symptoms...plus:
- Need to give it more revs to get off the line due to less stable engine RPM, as per less rotating mass / stored kinetic energy (but that's getting into the science of it all!)
- Clutch will wear out faster
- Requires alot more clutch slip for a forgiving/gentle take off
can u explain how the clutch would wear out faster?
the lighter flywheel was already in the car, and i have had no troubles with the idle or taking off at the lights, no noticable revving up,
ive been getting mixed answers about whether i should keep it or not, i am leaning towards keeping it as it was already in the car so id hate to put the standard one in and find that the car doesnt go as hard as before.
cheers for the answers guys
Well if it was already in the car then how are you going to know the difference between stock and not? You'd just be used to the lightened one with no comparison.
As I said it depends how much lighter the flywheel is...you say there's holes drilled...well that doesn't remove a great deal of weight from the thing (depending on size/number of holes). Have you weighed it yet?
Lightened flywheels wear out the clutch faster because they requires more slip for the gentle starts...and contact of clutch to flywheel is in general a harsher motion.
If you've been driving with it fine then just get it machined and keep it. No point changing something that works fine. As with anything, when you start removing material from it you compromise structural integrity so it will be slightly weaker than a standard flywheel but probably not enough to concern you. Some of the drastically reduced weight flywheels are pretty dangerous (read: come flying through the floorpan). Combine it with re-using high tensile flywheel bolts and you have a recipe for a nice time bomb.
A lightened flywheel will let you put on revs quicker , so you can spool up boost more quickly , but lowers torque , so you'll find yourself changing gears more often, it actualy can improve braking as you have less inertial mass spinning around to slow down.
Extreme lightness belongs on the track (if anywhere)and is an unnecessary pita on the street ime, a modest lightening can be a nice thing on the street from say 12 to 9/10 kg but you will lose a bit of torque. Its the old no action without reaction thingo.
It realy just depends what characteristics you are happiest with in your ride.
  • 3 months later...
Stick with stock. Don't go a lightened flywheel.
I have to putter around in 4th around town. I can't comfortably cruise in 5th until im up to atleast 70km/h. I used to be able to putter along in 5th at 60km/h.
Haven't really noticed if the revs came up faster or whatever.
I have noticed on takeoff that i have to give it more revs than before or it stalls.
Edited by r33cruiser
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
