hey guys.....was a pretty hot day today in Melbourne and unfortunately had to run some errands in this heat.
after returning i noticed the extreme amount of heat the engine was emitting...to the point i started getting worried. water temps were as high as 95 degrees and oil almost hitting 90.
i have a Koyo radiator that i recently just put on and had no dramas until today. most of the heat is comming from the exhaust housing (top mount gt35r) and there is no heatsheild.
can anyone give me some tips as to how i might overcome these problems? some people have mentioned ceramic coating the front/dump pipes and the exhaust housing. atm ive only got some shonky heat wrap.
any help much appreciated guys.
My oil is usually at 90, today went a tiny bit over due to Aircon on but hardly ever seen it over 90. Last year on those 46-47 degree days it got to a bit over 120 but 90 is fine dude. The water temp is a little high though.
I think properly made heat shields are the way to go , the heat insulation bags around the turbine housing are supposed to be good things too .
Ideally you want to keep the heat in the exhaust gas so it can do positive things for you , heat radiated into an engine bay does nothing for you .
A .
Driving around today, i didn't go past 75 degree's water temp. Every setup i've had has never gone above that either.
No heat shield is your issue, you are crazy to run around without one IMO.
Hmm, what exactly is a heat shield? Are we talking about something custom designed for the car?
I just have a Race Radiators item, it was made for a R33, but we modded the mounts, fits perfectly into a HR31.
That is basically it.
I also use the factory RB26 heat shields, RB26 clutch fan with shroud etc etc.
None of this wanky thermo business, just how Nissan intended it with a good quality radiator.
I have 1x A/C condenser and a radiator sized intercooler directly infront of the radiator as well, so its not exactly getting fresh air either :P
And i wouldn't say i have a massive 'mouth' on my front bar either.
The RB26 does sit lower in a HR31 than a GTR though (ie top of the cam gears is level with my radiator top), but i doubt that is anything major in terms of reasons.
Being he has a high mount, yes it will be custom made for the exhaust housing.
Usually just a 180degree bend of stainless that bolts on. Not hard for a fabricator with half a brain.
Cheers,
I was having trouble with mine last summer but i never knew because the factory temp gauge didnt move much. It wasn't until the tuner plugged it into his pc and took it for a drive (diagnosing another problem) we noticeed it around 90 degrees). Since then i have played with the clutch fan and have noticed a lot more air being pulled through.....i just have to wait until its back on the road!!!!
James
PS: I also have a 4.2EFI patrol that is nearly identical in the engine bay minus the turbo. I plugged my consult thingy in and noticed when the factory gauge is on 1/4 its 84 degree (sits there on normal driving) and 1/2 is 89 degrees!!!
Nismo thermostat worthwhile or not whats the general consensus
rebuilding my rb26 at the moment an wondering if its worth the extra dollars
2530's poncams etc etc was making 429 hp before it spun a bearing so big baffelled sump etc going in now
found with stock rad an nissan clutchfan etc it kept temps under control well before even on trackdays etc in Darwin heat!
Edited by noone
I hated mine... made it almost impossible to get the car up to temp on cold Melbourne nights but you might not have that problem in Darwin!
90º water and oil is fine... no reason to stress out
while were having this talk .i thought id ask.can u run an aftermarket 50m radiator and still keep the clutch fan in place? and dose the 26 clutch fan make much of a diffrence?????
Cant answer your query regarding the 50mm rad though I am pretty sure they will fit okay
Nissan clutch fan and correct shroud was so so much better than thermofan on my 32
that plus an oil cooler and I really didnt have to worry bout temps on track even in Darwin temps
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
