anybody?
it's worth doing if you're looking to make >450-500kw or the valve seats in the head are low. Cutting for bigger valves does give you a little more to work with on the short side plus it's easier to get the seats at a good height after you replace valve guides because they rarely end up concentric to the seat when you replace them.
Proengines above has likely given the best advice.
If you have the head off and you are overhauling it anyway, then it's probably not a bad option as the price of oversize valves isn't any greater than standard valves.
I used oversize valves as I was trying to extend the envelope of small turbocharges on a larger displacement engine. Installed high lift and long duration cams also for this reason.
If you are building a big HP engine with a single turbo, personally I wouldn't bother as any gains will most likely be overshadowed by the fact you have a big huffer installed.
yes its much easier to pick the seat with bigger valves if guides are replaced...it also makes full use of the port job if its ported.
There are some interesting schools of thought on valve sizes and especially valve size ratios as in inlet to exhaust .
I'm not home ATM and don't have a calculator handy , basically I think the valve area of the exhaust side needs to be something like 0.73 of the inlet to do well .
I like David Vizards books on performance engine building and the one on BL's old A Series has lots of good principles outlined by someone who speaks real english .
In the third revision which I have he speaks about valve size ratios in relation to static compression ratio and why that ~ 0.73 ratio works with low compression ratios where something like the 0.68 works out better for high CR engines with big cams . To be honest he was relating to NA engines but generally turbo engines are lowish static CR before they come on boost .
I'd always try to enhance the hot side of a turbo engine because when it comes on boost it acts like a larger capacity NA engine exhaust flow wise so if it is to run well you can't really have exhaust restrictions when its running in a supercharged state .
There are advantages to running larger valves and some say that its a bit like running higher performance cams only changing valves is more involved because they are not really a bolt on .
I'd do valves before big cams because mild cams with big valves still behave nicely because the mild cam timing , wild cam splutter to me has everything to do with trapping efficiency and overlap timing .
What I think is being sort after here is increased volumetric efficiency and while there's different ways to achieve it some give better overall results than others .
I am no one in the scheme of things but given a choice with an RB25/26/30 I'd like to go one size up on the exhaust valves , I get the feeling that RB26's that have done any considerable mileage need exhaust guides anyway so cutting the seats for a slightly larger valve is no biggie . Fresh valve stems are nice in new guides to , critical heat transfer points through exhaust valve seats and guides .
If you are careful with CR cams and turbo sizing I don't think you'd lose anything significant down low with slightly larger valves all round . I also think a well ported head makes a ig difference to the engines overall breathing characteristics .
Your call , cheers A .
But what brand of valve do you go for. The RB26, SR20 etc use soldum filled exhaust valves dont they, so help keep the exhaust valve cool. A simply stainless steel exhaust valve would almost be a downgrade wouldnt it when it comes to keepng combustion chamber temperatures down???????
We got good results with our head, full ferrea kit but we also did a plenum change so its hard to quantify the valves alone but torque is broader and holds 50nm at a minimum more to redline. ill post up a comparo 2moro. Haed is off again to test quench area mods as we speak.
actually comparo is here (ignore the difference in response as the second run was on a lower ramp rate for run in which was 6 seconds instead of 10) power is the same within 2 or 3 kw between ramp rates http://www.skylinesaustralia.com/forums/Sh...96#entry4918296
Edited by URAS
From what I have read (which of course is not gospel - but another school of thought) there are pro's and con's of sodium filled valves. Ie. that the heat is drawn up the stem which then apparantly takes its toll on the valve guides.
Edited by juggernaut1
i use inconell exhaust valves :thumbsup:
not sure who does basic stainless alloy valves anymore. The fereas are all Tribological super alloys (superior to inconnel and lighter) The materials of these aftermarket valves be it super alloy or inconell are far superior than the std items sodium filled gear.
Inconell is exteremly heavy duty also but sometimes the extra weight is its downfall (valve float ect) for example its a nono in high reving big blocks or they become a consumable (ie every 20-40 passes)
I have nice site which explains all the alloys here: http://www.enginebuildermag.com/Article/25...so_special.aspx
Edited by URAS
Cool, but looking at their website Ferreas dont have off the sheld RB20 valves, lol so i am guessing that means more expensive custom :D
never looked for 20 vlaves TBH, i thought we were talking 26 :happy:
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
