I wish, each piece is indexed into a spiral to fit the confined space then sanded internally to smooth it out. I would be doing nearly as much welding with the pressed doughnuts and they aren't cheap or tight enough.
The hole in the doughnut would need to be no bigger than about an inch.
I don't mind the welding, its good practice. :huh:
  • Replies 66
why dont you get it ceramic coated??
Cost.
I got enough ceramic wrap to do 20 inductions for $50, and I aint ripping the exhaust manifolds off to coat unless I have custom ones to go on. (with a gt3076 of course)
Edited by scotty nm35
Alright, so latest (and last) fuel economy update for those that are interested
Usual trips to and from work with a (very) heavy foot :P and about 100kms worth of freeway cruising
65L
549kms
roughly 8.5km/L or 11.8L/100kms.... so still good IMO
Edited by iamhe77
Usual trips to and from work with a (very) heavy foot :D and about 100kms worth of freeway cruising
65L
549kms
not bad without a tune! :D
22kw increase, not bad I thought.
Cihan thought I may be maxing the compressor so I guess i need to free up more restrictions, like the turbo outlet pipe next. Must be well over 400 horse at the crank now so the ATP highflow is doing pretty well considering.
Mmm, need to find some way of jigging these up off the car. Anybody got a spare turbo laying around? :D
will do soon, Cam had it but it has gone to be rebuilt and the broken one will be off the car next week.
I cen send it to you when I get it back if that will speed up the process.
Cheers
Andy
I can send it to you when I get it back if that will speed up the process.
Cheers
Andy
Turbo broad minded person!!!!
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
