Just a quick question....
if im in Brisbane where can i get my aircon gas refilled and how much is it??
I have never had the aircon working since i had my ceffy imported....was degassed before import
Summer is coming and i cant stand the heat any more.
Where can i get a refill? is it as easy as that??
Thanks to any of you who can direct me to the right path
https://www.sau.com.au/forums/topic/296530-refill-air-con-where/
What car, if its a 89-94, it's likely it takes R12 gas, I believe there is a universal gas that can go in it but is not as cold as old-school R12 (the current gas, R143a or R134a isnt compatible in R12 systems). I would guess the seals would have long dried and might need replacing.. if it's just a straight regas looking at about $100 (assuming the compressor still works)
Any autoelectrician > get a couple of quotes if you like > get a leak test; but...
It depends on...
a) if your system needs to be changed from old R12 refrigerant system to the current R134a system
b) condition of your compressor
c) condition of your condensor
d) your existing system has no leaks thru dried out seals as stated by Moodles2
When was your car manufactured?
as have been said, lots of places will do it, and provided it is as simple as putting new gas in it should only take an hour or less and should only cost $100. i've had it done for less, but i'm in a small town. they will generally vaccum out any old gas before refilling the gas.
not sure the cost if it needs the conversion done.
$100 Bucks!! everytime and everywhere quotes me $200-$300. plz share ur contacts.
The auto aircon place i pass everyday always has their "Regas for summer $100" sign out, and other mechanic shop franchises advertise about the same.
I once took my Pulsar in to see if the aircon could be fixed, needed new condensor, new compressor, new fan belt, new seals etc which ended up being quoted a touch over 1k (if memory serves right)... i don't think the aircon had been used on it in many many years
as i said, i'm in a small town. but if you are in brissy it might be worth the drive up. only cost you about $40 in fuel. the place i got it done was called coola auto air. actually last time i was there there was a r33 gtr having the conversion done. the guy is an older guy, but owns about 3 or 4 toyota imports (chasers or celciors, 1 of the 2) and i think 1 has a supercharged 1uzfe in it
If it's an '88 and hasn't had the A/C system changed to the new gas refrigerant, it WILL need to be changed now. The old R12 gas can't be used anymore due to it destroying the ozone layer. Some old dudes in camarofirebirdownersaustralia.com.au (and others) might have some of the old gas left but it's all hush-hush.
I just got my A/C checked and refilled, plus a second hand cluster installed for a grand total of... $80. :D
I'm in syd tho.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
