hi all,
just a newbie about to purchase my first skyline
1993 hr32 gtst 105xxx kms
had its 100,000 k service done, timing belt changed.
Following Mods;
Nismo GT-R Bodykit
East-Bear Bonnet
Koyo Radiator
GReddy Spec LS Front Mount Intercooler
Trust Airinx Pod Filter
GReddy Oil Catch Can
Apexi "Pencil Type" Turbo Timer
Swoosh Boost & Oil Temp Gauges - Dual Gauge Holder
RS-R* Piping from Dump to Cat
Trust MX Exhaust Cat Back
KYB Short Stroke Struts - King Springs
Endless Carbon Brake Pads
Comes with Original Suspension, Original Bonnet & Original Intercooler
are these quality mods?
is 11k around the mark for a very clean looking 32 gtst
any help would be appreciated :D
Edited by shibby69
https://www.sau.com.au/forums/topic/296542-about-to-purchase-93-hr32-gtst/
hi all,
Following Mods;
Nismo GT-R Bodykit
East-Bear Bonnet
Koyo Radiator
any help would be appreciated ;)
A nice list of upgrades it's got there.
The main thing is, what is the condition of the engine, turbo, mechanics and electrics..?
Get it checked out and test drive it. By driving the car you will be able to tell if there is any uncertainties of the car.
Turbo Timers are there so you can let your car sit and idle, saving you from waiting a few minutes.
+ you can set the alarm/lock up and the car will only switch off when the count down is finished.
Cool-down period required to prevent premature turbo wear and failure.
After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period of time, allowing the compressor assembly to cool from the lower gas temperatures in both the exhaust and intake tracts.
At the same time the lubricating oil from the engine is able to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed.
- http://en.wikipedia.org/wiki/Turbo_timer
thanks mate,
yeh i thought it drove really well on the test drive, its booked into jap motor sport in adelaide so the mechanic can do a full check and compression test. fingers crossed, could have it by the weekend.
what sort of power would it make with these mods? and what mods should i be looking at next?
im thinking fuel pump and injectors. a new turbo would probably be out of my price range
thanks mate,
Good! :wave:
Getting you mechanic to do a full inspection on the car will give you a peace of mind and let you know if it's good of not.
You do have some quality upgrades there, here is a quick run down of what they do...
Nismo GT-R Bodykit, the R32 GTR front bar has air vents to allow air flow to the FMIC and give the car decent look.
East-Bear Bonnet, has a vent to allow the heat out of the engine bay.
Koyo Radiator will keep your water temps at a lower / steadier temp so the car does not get too hot at the same time keep the lower temp more stable for longer spirited / track runs.
GReddy Spec LS Front Mount Intercooler for better air flow and cooling into the inlet plenum. You may experience a slight lag due to the front mount (on stock Boost) but if you are running higher boost, you won't notice it.
Trust Airinx Pod Filter for more air to go into the turbo, but can suck in hot air and you don't want that. Best shield off the pod or put the stock air box back on.
GReddy Oil Catch Can collects blow-by gasses that can create damaging carbon and oil sludge build-up in your intake including your intercooler. For Mid to Highly modified cars, if your car is stock, you won't need it.
Apexi "Pencil Type" Turbo Timer, as explained in my last post.
Swoosh Boost & Oil Temp Gauges - Dual Gauge Holder, aftermarket gauges are more accurate then the stock gauges, lets you keep track of your turbo boost pressures and oil temps.
^^ You got a full/turbo back exhaust system to allow better exhaust flow and you will gain a bit of power there.
KYB Short Stroke Struts, great for handling and as they are Short Stroke, the car will sit lower = lower centre of gravity, better control you have over the car = the faster you can turn corners.
King Springs, these will be harder then the stock ones and will add to the handling as mentioned above.
Endless Carbon Brake Pads, I think you have these pads in,
"The Endless CC-A compound is a Ceramic Carbon Brake Pad that provides superb pedal feel.
Designed to exhibit none of the negative characteristics that ceramic carbon compounds are known to have, such as low friction at lower temperatures, the CC-A compound has excellent cold bite while producing minimal amounts of dust and noise.
The Endless CC-A pads do all this while still being friendly to rotors, perfect for a high performance street pad." - http://www.endlessusa.com/brakepad/cc-a/
Higher quality pads then standard.
A stock R32 GTS-T is about 158kW's at the fly wheel (I think), from memory you lose about 25% through out the drivetrain + every dyno will have a different reading.
To be honest I can't say how many kW's the car will have, but at the moment the exhaust will be the one giving most of the power upgrade. (15-20 Kw's) maybe...
If the car is running stock boost, then the air pod and FMIC will give it a few more kW's but nothing huge.
I can easily say this car has probably seen a few track days / drift events.
So your doing the right thing by getting it checked out and get your mechanic to check the turbo as well.
Cool!
  • 1 month later...
congratulations on the purchase
fyi: I recently bought a r32 4door gtst with rb26dett goodness..... track biatch only
got a highly mod'd stagea to keep the roads swept clean :P
where abouts in adelaide?
im down south
got a highly mod'd stagea to keep the roads swept clean :ninja:
im down south
nice, that thing would fly! both of em haha
awesome im in the east side.
runs reallly well expect for the sticker i got on it at the moment :)
got pulled into a defect station at the bay and got done for bonnet pins and being too low, lucky i got the stock springs and bonnet tho
im down south
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
