I just got some 3M carbon fibre vinyl wraps from USA (you can actually feel the weaves), so I decided to have a go wraping my door pillars.
I'm going to wrap some of my interior (dash surrounds, plastics on doors) and maybe exterior (spoiler stands).
If anyone needs things wrapped, I could supply and wrap it at a cost :P
Here's some pics:
https://www.sau.com.au/forums/topic/296681-carbon-fibre-vinyl-wrap/
  • Replies 477
Looks excellent! Great work! :happy:
How easy is it to take off the door pillars? Do they just pull off or are they bolted from behind or something?
Cheers. :P
If you haven't taken off before, it might take a bit more force, but pretty much just open your door, then start from the bottom, start to pull it back slowly.
You should hear 3 clicks, because of 3 plastic bolts thingys, after that, just wiggle it left to right, then it should come out :)
hey just a quick question,
is its ver durable? and can it stand heat sun damage? and water damage?
cause i was thinking of buying somw this stuff
BTW it looks very good i wanna do this to my liner
This is one of the best vinyl wrap in the market at the moment, it's made for indoor and outdoor. indoor it should last forever while outdoor maybe 8-9years of sun and rain.
oh wow that stuff looks awesome, got a price on it?
Price for this can vary, range from $80-110 for 1.2m by 0.6m. It is very expensive but its worth it.
I got a day off today, so I decided to do more of my car, and I picked the cup holder lid.
As soon as I finished, I feel addicted to doing more LOL, I'm planning to do my whole centre console, climate control and my triple guage cover :down:
If anyone wants it done in Vic, I'm willing to do a piece for $20-40 (depends on size of part).
oh god, wets pants...
im going to hit up our vinyl suppliers at work, i know someone who stocks this, hopefully i can get it cheaper cos as you said it is pretty expensive, do you have a heat gun?
btw if this is the 3M DI-NOC stuff, i've found that it is rated at 3-4 years ourdoor and 12 years indoor
Yeah I have a heat gun and it is the DI NOC stuff, but last time I read about it was like 8-9 years outdoor.
Heres a spec sheet for ya dude,
http://multimedia.3m.com/mws/mediawebserve...s6EVs6E666666--
4 years outdoors, 3 years in desert conditions, and 12 years indoors, all by US standards of course
oh no doubt, looks awesome, im definatly gonna look into getting some
Yeah, the finish looks better in real life than in photos, I'm planning to get more lol, kinda addicted to wrapping things :thumbsup:
haha nice, i can see why,
If i could afford it, i would probably to the door skins, then again, that might be over kill, maybe just rip off the door card material and do those, as well as the whole centre console/triple gauge
Well it does kinda go with the R34 interior pattern lol :thumbsup:
When I get more time, I'll do more and post it up :D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
