eat cake
WE LIKE A BIT O' CAKE, DON'T WE
I KNOW I DO. I LOVE A BIT. I DO, I LOVE A BIT A CAKE
I DO, I JUST LIKE CAKE!
I'M JUST ONE OF THOSE PEOPLE, A COME HOME, AND ALL I WANT IS A SLICE OF CAKE
I JUST LOVE CAKE, I JUST LOVE CAKE, I JUST LOVE A BIT OF CAKE
CAAAKKKEEEE!!! I LOVE A BIT OF CAKE
https://www.sau.com.au/forums/topic/296870-birthday-notice/#findComment-4945134
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
