Anyone expriencing this? My head is shaved about .4mm and it has about 190psi in all cylinders, so I am guessing 9.5/1 compression ratio. Does good on the upper RPM range, but at initial take off or going up a hill at low RPMs, it pings a little when hot. Other background is thie injectors were just changed, happened before. Also, I have a wideband O2 sensor and it stays pretty steady at 14.7 during the pinging. It has been timed a few time since I noticed this. I am thinking two things, bad TPS or too much timing at low RPMs. I have tried to remove timing from the ignition map at low RPM but I am tuning blind as I dont have access to a map tracer. The stock advance is around 45 degrees at low load. Should be less with higher compression. I use 93 octane fuel BTW.
https://www.sau.com.au/forums/topic/297048-high-gear-low-rpm-ping-in-my-car/
dude, change down a gear! labouring your GTR up a hill in 5th at 60km/h and 2100rpm witb 100% throttle and high load is always going to be bad for it and make it ping. you could probably tune around it but these high load conditions are always bad news. the easy solution is drop down a gear or two. it is a sports car after all and quite a peaky one at that. GTRs aren't giving you their best at anything under about 4500rpm. sure cruising is one thing, but labouring it up a hill is just bad all round.
Check your ignition timing, you might need to wind it back a couple degree's to counter the extra compression, but as said before, use a lower gear, its much better for your engine.
Edited by SKiT_R31
The thing that I really worry about is the normal take off like from a stop sign. I always drop it down a gear to keep it above 2500rpms going up a hill, but my wife likes to drive it like a V8, 1200rpms chugging up a long hill. She gets mad at me when I correct her. If I drop back timing it will be in the ignition map, not on the CAS.
If she won't drive it like it should be driven, don't give her the keys ;)
My experience is that RBs like fuel to get rid of ping.
Damn straight... I'd rather an argument with the missus not being allowed to drive it then a 10G rebuild fee...
if he is using 93 i assume that he is in the USA? if so that's equivalent to our 98.
Actually, some parts of the USA only get 91 octane or less (particularly People's Republic of Kalifornia). Likewise, during winter months, the additives can get a bit heavy; further reducing the octane of the fuel.
He's in Okinawa (japan) and running japanese high octane. That's a little silly saying "just shift gears". It shouldn't do that if it's properly tuned, which is what he's trying to do. He's using a rom tune that he's doing himself. What he's asking (I'm guessing) is what else could make it knock. I still think it's just timing and more needs to be pulled out, but I understand that's hard to do with out a map tracer.
Winston, what's it knocking? Also, isn't it kicking itself down into the "knock maps"?
Yes, Chris is correct in saying that I am running Rom tuned R32 GTR ECU. The fuel that I use is the equivelant to US grade 93 Octane. I am not sure if they use a winter grade here in Okinawa, but it has been pinging for a while, maybe August.
I am going to borrow a Map tracer from Casey sometime to use for other tuning purposes. I will just log the area of the map at that time that pings. Funny thing about the knock map is it looks the same as the normal map. Datascan should also tell me if it goes into the knock map anyway. I am going to just pull a bit of timing off the bottom of both Maps and see what it does.
  • 1 month later...
An update on this topic. I always hate an unanswered problem when it falls by the wayside. The problem is all but gone now. I have cut almost 6 degrees out of the first 3000rpm of the timing map. I get a ping every once in a while, but its about 99% gone. Now the base timing is 15 degrees. This was adjusted in the map, not by turning the CAS. Now it spools a little better too, extra bonus. I think in the mid range, spool can be had at the sacrifice of power by retarding the timing. The trick is to find the proper medium in between spool and power. I am posting up the map to show how much timing I had to remove. Geen is stock RB26, red is my map.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
