Ok I am realy pissed at Wolf 3D for selling me this Ecu for my skyline it was a plug and play unit, but that was no where near the case.
Ok I but the unit and hand a work shop fitthe unit and tune it for me ...ok no problems! They fitted the unit ok plugged straight in and and they tuned the unit.
Ok in the tuning process the car was pinging and stuff ok the tunners rang up steve at Wolf and he said that 3 out of ten skylines have this problem. Ok fair enough so he sold us a new trigger switch for the car. Ok to fit this to the car the original unit had to be moderfied (OK NOT A PLUG AND PLAY UNIT NOW) any way this cost me some extra cash and it didn't sort the problem! .........#*@^ !
ok we called wolf again and he said to try wiring in some resisters in the loom .......we said what the #*@^ isn't it a plug and play unit, he then said that 'MIGHT' fix the problem. anyway we said his unit was a not what was stated, and returned it.
he also said it might be the car but the car was fine with the standard computer.
But I had to return the trigger switch back to standard. and the tunner spent 3 days on the car to get it to work + machine work fuel and track time. cost me a pretty penny in tune time and shit.
so to anyone thinking to get one of these WOLF units fitted into there car think again! nothing but problems!
:D:) :) shame ,shame, shame.
https://www.sau.com.au/forums/topic/29793-wolf-3ds-not-a-plug-and-play-system/
iv had no problems
plugged in, tuned and on my way...
its been two years now
I second that!
Unit is only as good as the tunner, and if the tunner does not know how to use the Wolf properly, then it's just asking for trouble.
Is there such a thing as a series V or 8 wolf? are they newer than the one Al and Whistla has?
I was mighty impressed by Al's unit, and was considering one.... hrm, maybe i should stick instead to tried and tested units instead.... Does anyone have an FCon V installed by any chance?
I've just bought a V4 Wolf3D plug-in for my R33 GTST, I know it's a V4 Rev5, don't know about V4.55 :confused: It has gone in my Skyline a couple of times and I still haven't got it working properly as yet but I haven't taken it to get tuned in properly yet, my Skyline is a Auto and as far as I know the Wolf's don't have a problem with the Auto's.
My Skyline is Standard other then a Jamex panel filter and the base Map didn't work with that, Steve-sst emailed me a Map and it worked, I just cant get it to idle as yet and I need to have my foot slightly on the accelerator to keep it at idle, when I let my foot of the accelerator it drops to just under 500rpm then conks out. We think the TPS might be a little iffy, have to check it out, haven’t had the time hopefully I’ll get to it soon and the Skyline want see a tune shop until after Christmas.
This person may be a good mechanic, but if you just ordered the unit and asked someone who hasn't been trained on the unit and doesn't know it's full features, to tune it, you are asking for trouble.
Pinging sounds like a tunning problem not a unit problem.
I would sooner consider the Power FC b4 the Fcon V simply because there are more people who know how to tune them. But i would still buy the wolf b4 either of these, due to the security feature and a few others. The only thing the wolf lacks is a knock sensor, but if it is properly tunned it is not required.
I personally am still behind the Wolf, as i have had no problems that weren't related to tunning. At the start i also had some delemas, but with further tunning these have been eliminated.
Nizmokid if you didn't screw me over earlier this year i would have put my map/tune on a disk and send it to you, to use as a base tune, then get your mechanic to trim the "edges" to suit your car.
You never know when something will come back and bite you on the A$$!
Each car is different, thus needs to be tuned individually. This idle problem also sounds like the tune needs some more fine adjustment. MAP sensors are a little bit harder to get right.
At the start mine also had idle problems, but now it has been all ironed out :P.
If it's a "Plug and play" ECU, as the wolf is touted as being, then surely the wiring diagrams supplied with the unit should contain all the information needed to install the unit, and the base maps also supplied with the unit should at least be capable of getting the car to idle.... now, of course some tuning is going to be required, quite a lot in fact, but really, a decent ECU requires a tuner who knows how to tune EFI.... A "plug and play" ecu shouldnt really have any hidden features that require a specialist tuner to operate it...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
