best bet, talk to Jetwreck as he has sorted through these problems for someone at least once before.
mmm.. Nagoya...
Have you changed your aircon filter (in the passenger footwell behind glove box) I pulled one out for someone and it was marked that it was changed 2 years prior at 70k. Only thing was the car was purchased in Oz with 42k 2 years prior.... the plot thickened.
So that sticker has the km it was changed at or the km to change it next?
Penrite also make a compatible oil for matic J which is full synthetic.
I payed closer attention today when I put the car into Drive... The clunking seems to come from the rear.. Obviously the diff has backlash.. BUT the car lurches Forward when it does into Drive.
Sound strange?
I'll so a service on the box, I'll use penrite 100% synthetic, it is matic J compatible.. Dno what you guys think of penrite, but I even use it to oil my BBQ.. (Jokes right)
Is the filter a gauze type? So it is serviceable, no need for replacing?
Checked out the AC filter... no date or anything on it.
slightly off topic
found this behind the glove box
no idea wat it does, got some switch on the right side of the centre console...its doing something, but at the same time nothing ( obviously with the TV)
anyway, back to topic
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
