SLY33 has come along way since the old TORANA days.. hahah everytime i see him, he always has a new girl and the same WIDE smile... STUD!
HAHA, nah its just that girls are always changing their hair colour these days. Same chick different day :rofl:
I havent come all that far dude, last 2 nights ive been cruising in the GUZLER! Old school style! I miss the rumbling and the avgas fumes...!
seen her around... she looks ok...... but then again, sly33 is pretty quick with the gals!! :rofl:
dude you'll give me a bad reputation! and besides i can go nearly three minutes these days! :wassup:
you're right you haven't had a proper look :Oops:
but you are in luck, she puts out to pretty much anyone :wassup:
/rant off
haha, you girls crack me up! Like i said, i havent had a propper look!
Miss_Nismo, i dont put out to pretty much anyone! (what has N/A been saying? :cheers: haha), i just wondered if she was hot. When are you coming for a cruise with me? -but im very superficial so you have to be hot, just ask N/A :D
Enrico, you can have my old bikini girl avatar if you want it!
  • Replies 425
PS, dont prefer imported girls myself... and im half import!@ :cheers:
on the topic of this thread though, i saw a yellow 180sx, may have had a black roof and white rims. Pretty sure i remember Viva garage stickers on it. It was on anzac highway, he wouldnt run me.
I know you prefer the LOOCALLL stuff essaee.... That yellow 180 looks pretty good.
He works wit me, dont know him though, it has a s15 front with sil1580 plates. sprayed it him self.
the guy that owns the morpowa yellow 33 told be it would make about 350rwkws. I wasnt sure to believe him cos he was only using a relatively med sized turbo. cant remember what type it was. Also at that time, the car was in pieces, so not sure if its together yet.
they're starting work again on the yellow gts at morpowa this week, had been put on hold due to alot of work going into the lancer at the nationals.
not an import, but funny anywho... saw a silver VT commy, dual mufflers and chrome rims, with the number plates RIMJ 08
SOMEONE TELL ME THAT ISNT A GREAT CAR FOR UNDERCOVERS!
I saw a white 33 (with Jap stickers on it, white mags and a black GT wing) on the back of a trailer on Lower North East Rd this arvo - it had a nasty bingle on the front end :)
ahh ya i saw that one.. its at provident crash repairs atm.. front end damage looked pretty bad!!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
