Price is $84,000.00
here it is again if you missed it the first time..
$100,000 spent and 3.5 years of hard work has gone into making this one of the best R34 GTRs in the country. Its super fast, super quiet and super nice to drive.
The key thing to understand with any GTR is that you may save money up front on the car, but they all will require a lot of money to keep running.
My car has had absolutely everything that needs to be done to it done in order to make it completely bullet proof and easy to own.
In fact, all you will need to do with this car is change the oil regularly and service the car as if it were a standard car. The car is built to such a high quality that it will run at this state of tune indefinately.
Currently my car is tuned to 380 rear wheel kilowatts on the Racepace dyno. Tuned by the master, Ben Dirks (Beno). Its awesome !!
The HKS 2.8 Step2 motor was built personally by Ben to offer the best possible level of reliability. I was not specificially after top end power. I wanted drivability and performance and most of all reliability. The entire motor was built from brand new components.
FYI, Any 2.6 engine that runs a standard crank will cause you problems if the power level is 340 rear wheel kilowatts or higher. The standard crank is not counter balanced and when driven hard at high output, will crack the block and wear bearings fast.
The HKS 2.8 is built with a forged lightweight counter balanced crankshaft, billet H Beam rods and the step 2 pistons. The kit is specified to deliver 800HP. Mine is tuned to around 550HP leaving plenty of tollerance for longevity. If you want more power, turn up the boost and timing.
It has a near new Harrop brake kit with 381mm 6 pistons on the front and 343mm 4 pistons on the rear. All lines are custom made dot approved braided steel.
Every suspension component was replaced with top quality jap parts with custom valved Tein RA shocks.
The multifunction display and speedo cluster is NISMO genuine items. 2 grand alone for these.
the list goes on and on. If you start at the very front and work you way to the tip of the exhaust, everything you come across has been upgraded or modified to deliver the absolute best GTR experience possible balanced with the reality of driving on public roads and going to the track and kicking everyones ass. This is the car to do it in ...
Let me know if you want to know more...
https://www.sau.com.au/forums/topic/298941-r34gtr-vspec/
  • Replies 48
bit more info in his carsales ad
awesome car & good luck with the sale.
If my numbers come up sat night I'll give you a call
cheers, tim
^ why? you can just transfer rego
couple things
year and km's? how many km's since built?
price is firm?
cheers,
daniel
https://www.sau.com.au/forums/topic/298941-r34gtr-vspec/#findComment-4972191
Thanks Gohan....
Its been in the garage for 2 years. Thats basically from when all the work was done. It's only been out to go to Superlap in Sydney last year and to Winton this year. Total of around 20 laps which only about 5 were on the throttle...
The rest of the driving is from my place to my mates place in Mill Park.
From what I know, these kinds of engines will run thousands of laps and still give you plenty of driving time for cruising the streets before even thinking about freshening bearings etc...
This one is all new and shiny still. Hasn't been all used up like a 50 year old prostitute. Its essentially a virgin in car terms....
https://www.sau.com.au/forums/topic/298941-r34gtr-vspec/#findComment-4972360
if i had 84k this would be mine in a heartbeat, and i wouldn't bother haggling.... hell i'd go 90k... i loved this car from the moment i first saw it
gl and freebump
https://www.sau.com.au/forums/topic/298941-r34gtr-vspec/#findComment-4978251
WTF? I don't understand why this hasn't been bought already. Whats the story??
It aint the car......I'm not sure how easy it would be to borrow that amount of money for that car. If it was a shit fighting BMW 1 series you'd have no problem because there is an established market and value for them. If you can't borrow it then you've got to come up with the cash and who has that kind of cash sitting around after all life's other expenses. I guess you could borrow the market value of a stocker and pay the difference in cash? That amount on an import will still not be easy....
I've got 2 R32 GTRs leased through my business and the leasing companies we go through always hit me up with high rates and fees etc as they just do not like lending against this kind of stuff. We lease 30 vehicles and a lot of equipment and still they baulk.
That said, you'll find someone, I just think they might be a rare breed.
Larverly car.....I'd buy it in a flash but I'd have to ditch my wife and family for it....... :)
https://www.sau.com.au/forums/topic/298941-r34gtr-vspec/#findComment-4978494
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
