Ok I am new to the forums and millimeters away from purchasing my first skyline (93 r33 gtst), BUT there's one problem the aircon does not work.
Has anyone experienced any aircon problems and or had to replace any parts? Are the parts readily available to start with?
Need to know worst case scenario of how much it will cost to repair so I can account for it in the purchase price.
All feedback will be appreciated.
Cheers,
Tay
https://www.sau.com.au/forums/topic/29898-aircon-problems/
Well I have a 93 R33 as well but haven't had any problems with the aircon. Except i had to get it regassed the other day for the princely sum on $99 inc labour.
Unless the car is an absolute bargain don't buy it with obvious problems, just move on to the next Skyline. There's a million around.
Parts for the aircon will be available easily and any aircon place will be able to work on it. The only issue is if you need to replace major parts like the compressor or get the entire system repiped.
Worst case you're looking at up to two grand including diagnosing the problem.
In other words, it could cost you more than the difference between this car and another bargain R33.
https://www.sau.com.au/forums/topic/29898-aircon-problems/#findComment-608356
Hmm..2K?? that's sounds pretty steep.
This car ain't quite a bargain but I think I am willing to take a punt (and just hope it's a quick fix). I will have to take a significant chunk out of the offer though.
Cheers.
https://www.sau.com.au/forums/topic/29898-aircon-problems/#findComment-609810
when you say not working, what do you mean? If the fans are going but you're only getting warm air it could be the coolent needs replacing, or there could be a leak in the system. If you're not even getting the fans going, the problem could be electrical.
Also be aware that sometimes Japanese owners will strip out the aircon system to save weight and avoid losing power! I've seen this done to a couple of cars.
https://www.sau.com.au/forums/topic/29898-aircon-problems/#findComment-609945
Ok against all advice it would seem I have bought the car and am very very pleased to become a Skyline owner for the first time (yeehaa!!!).
I managed to negotiate a few hundred off the already haggled price so I am not too displeased. Perhaps I should let a pro have a look at it before I get too excited. Aircon is all there it just blows hot air....hmm anyway I will let you know.
Thanks for the help.
https://www.sau.com.au/forums/topic/29898-aircon-problems/#findComment-611187
This is the first thing I will try.
Apparently nothing will work if the gas gets to a certain (low) level. Hope this theory is true. As long as everything works and its just got a leak (be it major or minor) I will be happy to get it fixed.
Coz damn its hot in Perth.
https://www.sau.com.au/forums/topic/29898-aircon-problems/#findComment-611757
afaik a/c's have a pressure switch, when the pressure gets to low, the switch breaks the circuit so that the clutch cannot engage.
sorry they don't have a low pressure switch at all reason you think clutch isn't engaged is because no gas = no load from compressor.
they only have a high pressure switch to cut out compressor, you need this because most car a/c regas places overcharge.
your a/c runs but only hot air comes out means only 2 things low gas or compressor not pumping, now there are to many reasons to list causes but most common is compressor seal leaks due to wear & only fix is reco compressor (car compressor is belt driven so mech esal is side loaded so any bearing wear or over tighten belt causes seal to wear faster causing gas to leak because it's the sealing medium).
car a/c systems hold very little refrigerant charge with most holding under 1kg which to put in dollars in cost if you have lic (like me) to buy it is about $20 per kg R134a.
https://www.sau.com.au/forums/topic/29898-aircon-problems/#findComment-612026
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
