Hi,
Although I am usually cautious, the other day I experimented with removing the boost restrictor on my R32 GTR to see what would happen. Car is mostly stock engine-wise, with only apexi pods and a 3.5" full exhaust (and perhaps what sounds suspiciously like an after-market fuel pump).
Some observations:
  • With the restrictor in, boost was peaking at 12.5psi
  • With the restrictor out, boost came on much quicker (:)) but peaked at just over 15psi (:P)
Some questions:
  • 12.5psi with the restrictor in seems pretty high compared to what I thought stock was (ie around 10?). Presume that this is just due to the free-er flowing exhaust?
  • I know people tend to be conservative with advising people against overboosting 15-year-old-ceramic-wheeled gtr turbos, but does anyone have insight as to what the safe limit is and whether peaking over 15psi is just stupid?
  • Rather than smash the old turbs, I am considering doing a full upgrade, but reckon that once I factor in turbos (~3k 2nd hand), a PFC (~$1k), injectors (~$0.7k) and a decent oil cooler (~$0.7k) I'm looking at around $6k plus $1k of labour. Is that the ballpark?
Cheers
Some questions:
Cheers
An R32 GTR is 20 years old - if you don't have $10,000 for a rebuild run it at the 12.5psi (exhaust raises stock boost).
For the upgrade - factor in $1000 for tune as well but you might get injectors & cooler cheaper & turbo price would depend.
point taken. I do have $10k but would rather spend it on a build rather than a rebuild :P
Another question: Can anyone explain the theoretical function of the boost restrictor to me? I've been studying the vacuum diagram, and it looks like the restrictor is in the line that goes to the wastegate actuators. To me it seems counter-intuitive that removing the restrictor works the way it does,
my brain says:
  • restrictor in => actuator sees pressure lower/later => wastegate opens later => more/earlier boost
  • restrictor out => actuator sees pressure higher/earlier => wastegate opens earlier => less/later boost
but the car says
  • restrictor in => ...? => less/later boost
  • restrictor out => ...? => more/earlier boost
Edited by semislickR32
What are you using to measure the boost pressure? Just wondering if it is a gauge issue as I have had one do the same.
i'm using a turbosmart eBoost2 controller gauge, which should be relatively accurate I guess.
And just in case you're wondering "why don't you just use the eBoost2 to control the boost instead of removing the restrictor?", it's because I haven't figured out how to hook it up yet - it was much easier on my old S15 with one turbo, non-cram-packed engine bay and an easy-to-understand vacuum diagram.
The R32GTR diagram in the manual is difficult to interpret to figure out where to get the boost signal from and how to get the solenoid control signal to the actuators... and previous forum searches and questions haven't been answered - poor me :P
With the EBC, you can use the existing wastegate actuator hose that goes to the stock boost controller, but you can't use the manifold pressure source the factory hose uses as it's from an already bled location at the rear near the clutch, need a new hose ran from the intake manifold to the EBC (and the bled source one blanked off). It's how Boostworx did the piping to my Gizzmo MS-IBC's actuator.
thanks for the tip, that makes sense from looking at the diagram which shows that bleed. Do you happen to know whether the take-off from the intake manifold was from the fuel pressure reg signal line, or is there a better safer place to T in?
Thanks again...
FWIW my 120,000km old turbos let go at 13.5 psi on a very conservative tune. Factory turbo replacement interval is 100,000km and that's standard setup. Get the turbos changed now, the other stuff can wait until whenever you like.
New garrets will cost around $2600 for the pair - no need to go second hand. I'd guess installation would be at least $500, maybe a bit more. Do o2s at the same time, and if you're ever going to do the dumps do it at the same time.
Thanks again...
You know that black box in the enginebay on the firewall on the drivers side, thats the MAP sensor that feeds the triple gauge boost reading, I tee'd in there as the pressure source for the PSI reading. You can tee off at the FPR directly, it will technically be less laggy than tee'ing into what I used. The stock MAP sensor gets pressure reading from the FPR anyway, it just enters the balance tube first, and a hose comes out the other end to it, then connects to that black box.
With the engine pressure source (stock one is the bled source), I can't remember if mine is before or after the throttle bodies.
yep that's where I've got the PSI reading too.
so I take it you didn't use the MAP sensor lines or the FPR lines for the solenoid pressure source... but in theory could you? I guess the only post-throttle-body source would be off the balance tube anyway,
My understanding is that the best place for getting the signal for the solenoid is pre-throttle and pre-intercooler if possible, but I assume that would require drilling into the hotpipe - not my preference by a long shot.
That is where my solenoid feed is connected, a small barb threaded into the 'twin turbo' pipe just before the large hose going to the intercooler.. Signal is coming from the same point as the map sensor.
  • 2 months later...
i recently took out my boost restrictor after i fitted my front pipe and high flow cat, and my boost didnt increase after the restrictor was removed !
im still only getting around 11ish psi !
what can be the problem??
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
