Hi guys,
I recently brought an R32 as a daily, it's stock, runs stock boost etc.
It pings it absolute face off above about 4500rpm.
I wound the timing back as far as it can go (yes I know it's clockwise on the CAS) and it was better but I can still hear a few pings and that is will like 20RWKW down low because the timing is so retarded.
This is with 98 octane fuel (BP Ultimate) I have tried different fuels with the same result.
It doesn't ping coming on to boost which is kinda wierd, only at about 4000rpm+ once it starts to do something. Stock turbo is fully spooled way before then.
Any idea's guys? The boost is around 5psi at the intake manifold, also confirmed with another gauge.
I have an RB30DET in an R33 as a daily driver and I remember when that had the stock RB25DET in it, I use to run 12psi on 18 degrease of timing and it never pinged on 98 octane fuel. :)
Stock coil packs, Also have a receipt from the previous owner where it has just had new plugs put in it at a work shop. Not sure what they are and haven't pulled one out to look but I assume they would just be stock gap.
Not sure how spark plug gap or brand can make it ping.
It doesn't miss at all so I assumed it wouldn't be a spark related issue.
:) why didn't I think of that before...
I will stick a fuel pressure reg on and see how much fuel pressure the stock pump is holding... kinda have to test that under load though...
I think I have a set of RB20DET injectors lying around some where I will try changing them over... I hate removing intake manifolds on RBs so much :)
Will also try replacing the pump if I can find one lying around. I have a Bosch 044 lying around so I could run that in-line and see if that helps.
It's wierd cuz this car has really no power, I guess around 100RWKW if it's lucky. I would have thought the stock fuel gear wouldn't have a problem with it unless an injector is all clogged up or the stock fuel pressure reg is dying.
Edited by Finny
I replaced the pump with a new pump, voltages are fine. I really don't think it is a fuel issue as the car doesn't hesitate or have any signs of fuel starvation.
It also doesn't ping for like the first 2 minutes of driving until the car gets hot, I thought it could just need a cooler upgrade but no other R32 that I have seen pinged with stock cooler, In fact a friend of mine had an R32 with more than stock timing, 12psi and stock cooler and that had no issues.
I changed the computer to one that had been tuned to 180RWKW with stock injectors and the car will not rev. It has classic retarded timing issues like very slow free rev and at about 4500rpm it just wouldn't free rev any higher. Another sign or retarded timing was the exhaust was pooping heaps of flames due to the exhaust valve opening while the fuel was still burning. I didn't pay much attention to this as this ecu has not been tried in an R32 since it was brought off ebay by a friend so it could just be a dud tune. Also I adjusted the timing with the cas and it didn't help.
check if the vacuum line to the factory FPR is connected and not damaged. Sounds like a fuelling problem, when the car is cold by default it will run more rich hence less/no ping.
I suspect a faulty FPR or fuel pump.
A friend just pointed out to me, it's probably got like bosch temp 5 plugs as it had new plugs put in at a work shop, they used bosch plugs and a temp 5 in a bosch plug is like a temp 3 in an NGK. I am going to put some NGK temp 8 plugs in it and see if that fixes the issue.
sounds like ur timing belt hasnt been installed properly, check that first, spark plugs dont make u ping !! >.<
Agreed, he really needs to check the belt and see where all the markings are.
A betting man would put money on this.
Of course it is - it's pinging!
Because the engine is cold, and the ECU is running the engine rich.
... it's probably got like bosch temp 5 plugs ...
Have you actually looked to see what plugs are installed?
You still haven't told us what fuel pressure the engine is running.
If the plug is running too hot, it can pre-ignite the mixture (works like a glowplug).
You changed the pump and injectors but not the fuel filter??
You can measure all the fuel pressure you like but you also need to check the system flow, thats just as important.
Use a timing light; that will tell you where the timing actually is and if there is a possibility of the cam timing being out.
and also:
Are you sure its actually pinging?
Some boost leaks sometimes sound like knocking. Just an idea.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
