  • Replies 3.6k
Posted Images
looks like usf1 is a fail http://www.planetf1.com/story/0,18954,3213_5956816,00.html
and stephan gp are keen for an entry with all the ex toyota stuff, so keen they are shipping gear to the first gp hoping for a place on the grid
Stefan have actually shipped or are about to ship a container to the second round as well.
Must have some decent $$'s behind them if they're spending up without any indication if they'll be allowed to race.
Have they done any testing with the other teams?
Shame that if USF1 do pull out and Stefan GP do get the final two grid positions, is that teams like Lola and Prodrive missed out initially, and would have well and truly had a car ready for pre-season testing.
And, I hope they change the name of Stefan GP too, it's probably by far the worst name I've ever heard in the GP grid :down:
if i only went to exciting GP's, i'd never leave my house! Its all about going to Monaco, and im going to be in Barca and the sphincter of the universe anyway, might as well chuck in a few GP's and see what they're like over there
They cant be any more uneventful than the melbourne GP is every year. The only other 'have to' track is Spa, and that might happen next year
still not a massive fan of the looks, hopefully the finished product is a little more edgy
the noise tho, is very unexpected. You sort of think that it will have that empty sounding noise that ferrari's have and hopefully pump out more of the growly lambo sound... but no. Its almost like american muscle. sounds ace
I reckon the viewing should be good in the sphincter of the universe, you should be able to choose a seat next to the only other spectator. Say hi to Bernie from all of us at SAU.
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
