  • Replies 3.6k
Posted Images
This probably should have happened years ago, not that his dad has done a bad job (that I can tell) but F1 is several orders of magnitude bigger than anything else.
Is there any particular reason for ragging on Martin Brundle? Has he done a bad job previously? Bear in mind that his record as a driver has nothing to do with his skills (or lack of) as a manager.
I don't particularly care who manages a driver, unless they have a conflict of interest in managing a team as well (are you listening Flavio? Of course not). Hakkinen, though ... I'm not sure. I think he could do better. I don't recall him being noted for his media skills, one of the key skills for a manager (liaising with the media). The 2MB guys are much better at that (are they still together?).
Having Brundle commentate and manage a driver is like Eddie Macquire calling Collingwood games, there is already an established bias, whether intended or not... I'm not saying Brundle is a bad manager, in fact I bet he would be rather good, but to do so whilst he is commentating does tarnish his ability to be totally partial..
Perhaps, although bear in mind Brundle's role in the telecast, he's there as the technical expert and ex-driver, so he's there more to fill in the gaps from the other guy (I forget his name) than to give his opinion. At least that's the theory. I do agree, though, that when it comes to the media, you shouldn't play both sides of the street.
haha campos is now HRT F1.... wonder if the supporters will be a pack of bogans
HRT also stands for Hormone Replacement Therapy ... wouldn't want to be a woman working for that team. Or a girly man.
Will the bigger fuel tanks/loads be to the advantage of the larger drivers?
Could be, the driver weight difference will be a smaller percentage of the overall car weight so will affect the car's performance less. I don't think it makes a lot of difference anyway, they all bring the cars up to the minimum weight with ballast anyway. The only difference is the lighter drivers have more options re: placement of ballast.
    • Hi SAU family, having issues with my R34GTT which is slightly modified and tuned to e85. so scenario is, I’m driving the car to work (30km oneway) and then coming back in the arvo. Car starts and runs fine in the morning and on the way back home (in the arvo). I stop the car when i gets home and after 10-15 mins, it wont start. Battery is fine, fuel pump seems to be working. All i hear is engine clicks but wont start.  Last time, i disconnected the battery terminals and re connected them. Check fuses. Didnt start at that time but started after an hour (so I say when its cool down). Mechanic cant find the issue as its running now and nothing coming up in the diagnose. any advice,opinion or anyone gone through similar issue.   thanks 🙏🏻
    • 9" +35 will rub on the suspension. R33 GTR wheels are +30.
    • I know a guy with 18x9 +22 on the front of a 32 gtst, needed quite a lot of guard work, tyre stretch (215) and camber. Not sure what your current set up is, +35 won't be as much, but still a fair bit of guard work and camber.
    • Well as expected the ECU wasn't getting proper manifold pressure reading.  Once I switched to a 3rd vacuum line directly off the back of the manifold the car runs amazing.  Still slightly lean on full throttle but only like 15 AFR, probably fixable with some tuning.
    • Cliff's for those of us who refuse to even click a bookface link?
