  • Replies 3.6k
Posted Images
Wow. This could play massively into Marks hands if the race starts dry or only lightly wet with his inters. I'm expecting a huge points haul for Red Bull... mechanicals permitting.
What a rollercoaster ride of a qualifying session.
Well that was a brilliant qualifying session if you ask me! :P So much for Webs can't drive in the wet hey... Plenty of world champs and former world champs spinning and putting it in the gravel.... :down:
Bring on the race!! :D
The real queston is, how many laps do they have to bag in order to be classified a full points result. Last year Webber was on for perhaps his first GP win or at least a podium when it was called to a halt. I hope when/if the weather comes tomorrow it doesnt rob Webs of a good points haul.
If its a wet race they can start on whatever tyre they want, ditto a dry race
Do they not do the 'start on the same tyres' thing if Q3 is wet?
Only in the dry this rule applies, for the prime/option tires.. Well I'm pretty sure anyway.
Oh, and COP THAT SH*T WEBBER HATERZ.. Bring it home P1 sonny!
Please Schu, show us some of that old wet weather magic!
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
