As bad as that Buemi crash was..... did anyone else find it a little bit funny that he was trying to steer without any front wheels? lulz.
What a massive failure in the front end though! Very lucky that he wasnt injured. Just heard on fox news that Buemi says the crash was 'nothing serious'.... Lol WTF?
I've seen guys trying to steer their cars with their front ends pointing at the sky. It's a natural instinct I suppose.
  • Replies 3.6k
Posted Images
somewhat off topic, but fuck me, Craig Baird is becoming unbearabe
he brings nothing to 'the panel' except a shit accent and his own one-eyed views about how much he'd like to have schui's cock in, and around, his mouth.
Was great last year with Cam and thruster, why screw with the format? now we're stuck with this negative sob for the rest of the year
Agreed with Ivan. My missus was like "Who is this depressing idiot?"
Never really understood why 1HD don't have any practice sessions, especially since some of the other shit they broadcast is Netball. Seriously, who watches Netball?
Totally agree.... 1HD advertises F1 as one of its headlining events, yet won't show the practice sessions and instead they have some other dribble on that noone cares about....
I'm glad I'm not the only one that thinks Baird is terrible on the panel! I don't know who is worse though, our guys or Brundle crapping on continuously about Button and Hamilton.
Think you guys have it all wrong, they need to get Cromps back and ASAP! Now THAT bloke understands racing, and doesn't prattle crap, when he speaks, people listen (if you heard P. Brock's eulogy you know what I'm on about). Even if it means bringing the V8's back to ten, so be it.. Just gives them an excuse to telecast 2 OneHD channels! :-)
No more Cam, no more Rusty.. Don't mind Beattie but only in small'ish doses.. Trying to think of the guy that used to do it with Cromps, he is still at ten and is on the news, but his name escapes me, but I liked him a lot as well!
Oh, and go Webs! .3 quicker than the rest of the field! Yeewww!
Please Schumi, please set a time faster than Nico!!!
Imagine how many WDCs Webber would have if he had Rubens seat! I mean, Webber BLEW Rosberg away and Rosberg is BLOWING old man Schuey away, I think Webber would have had about 8 WDCs by now! ..... :(
...and as for commentary. Bring back Alan Jones, i understand he can do with the money
Well it looks like a Q3 shootout between Webber and Hamo for Pole. Vettel has been slower in S1 all weekend then Webber. Maybe Alonso is an outside chance.
And i have held off saying it...but i was right! :( No way they should have given the keys to the Mercedes to Schuey. I dare say Heidfeld right now would be doing the better job
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
