  • Replies 3.6k
Posted Images
I hate to say it but I think that prang was about 50/50 ... Kovi swerved defending a position he could never gave held, but
Webber was right on his arse when he didn't need to be. Kovi seemed to brake quite early though.
lol weber revisits his mercedes days.
what a hack
LOL too true. racing for position you must go around the other car, not through them and over them.
everyone at BBC whinging about how he should just let someone through can shut up. webber brain fart 100%, he makes his own luck.
we were just told the lotus was defending, he wasn't leaving a line open.
So how many laps did that take the stewards to make a decision about the drive through? and how long did hamo take to DO the drive through?
    • If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well.
    • It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
    • Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
    • I already have an Apexi. Just wondering if it is worth putting in something new since the Apexi is likely well over 10 years old, if not 15. I know the injectors work but they already run at less than rated fuel pressure to make them work properly and idle is basically 1% duty cycle or less. Could be better
    • Nice, I would never have thought in that direction. The actual motor is a cylinder....I wonder if there are any cylindrical heat sinks with the right ID  (and if there is clearance to other components). I think adding airflow is still a thing as well....will check it all out next time it is in the air. Wish I had a hoist...
