This facade that RBR are putting on in regards to equal billing is turning fans away.
Do they believe that we are so stupid not to catch on?
RBR can go and choke on a bag of Dicks!
If it wasn't for Capt Chin having decent success, I am sure we would all just walk away from giving them any sort of support
No doubt they will be 1-2 after the race,
Hopefully MW in front.
However I will be rubbing every lucky foot and Voodoo Doll I have to see I'matool spear off into the country side.
  • Replies 3.6k
Posted Images
Yeah I didn't understand that. I started punching the couch when he qualied first. Can't stand him anymore.
Noticed Nando was taking a looong hard look at the RB6 after qualifying though. He might think theres something suss (but we all know he is prone to have a sook).
Hopefully Webber finishes first, SV and FA tangle, and Hamilton second :thumbsup:
not to side with RBR but I probably would have done the same thing given that Vettel is ahead in the championship and therefore you would try to give him the best opportunity of winning the WDC.
Of course my main gripe is that RBR did not provide the same support to Webber when he was leading the championship, by giving poor team orders in the sphincter of the universe in both the race and qualifying and using the bad strategy for Canada when clearly they should have made it Webber ahead of Vettel given their relative positions in the WDC at that time.
It's obvious to see where RBR's allegience lies, I guess Webber signed on for further years because he thinks RBR is still the best chance for a WDC win in the coming years, but he'll be saddened to find out he'll just end up like Barachello.
Webber has been in front of Vettel, had a better quaifying record this year, has won as mang GPs as Vettel this year, there are still 10 GPs to go... Vettel being ahead on points means very little at the moment.
Earlier in the year was Helmut Marko at every GP? I recall that he used to only turn up to the occassional race and often commented from a distance about the team. Interesting to see him in the pits the last few weekends since the sphincter of the universe! ???????
If you're talking head to head Vettel leads Webber 5-4 in qualifying, I believe.
5-5 So even stevens now. So Webber was 5-4 up on Vettel
Whats the bet that if Webber is able to shadow (if) Vettel up to the first pit stop he gets no chace of jumping with either an early or later stop. They will be pulled in within a lap of one another meaning status quo
No, 5-4 includes yesterday. It was 4-all
Hang on , wires are being crossed here. Silverstone is the 10th GP of the season. So how do you have 5-4????
Bahrian: Vettel
Australia: Vettel
Malaysia: Webber
China: Vettel
Spain : Webber
Monaco: Webber
the sphincter of the universe: Webber
Canada: Webber
European GP: Vettel
Silverstone: Vettel
Bahrian: Vettel
Australia: Vettel
Malaysia: Webber
China: Vettel
Spain : Webber
Monaco: Webber
Canada: Webber
European GP: Vettel
Silverstone: Vettel
I think I forgot the one where neither of them got pole
Very obvious where the RBR allegiance lies. They should have said sorry seb, yours got damaged mark kept his in good nick. there's f**k all difference anyway so just get out there and get on it.
To actually take it off one drivers car and put it on the others is showing that with only 12 points difference at the halfway point in the season they are already using any chance to give Vettel an advantage and make sure he wins WDC not Webber.
if it was 3 races to go and vettel had 20 points on his teammate then sure. but now it's just a flimsy excuse.
I'm going to tip that the first three places will be as qualified. Much as I want to see webber get up I don't think he'll be able to get around vetool
Hmmm with mark on the dirty side he'll be lucky to be third by the end of the 2nd corner, Having said that i hope mark rips that little prats wing of into turn one. :banana:
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
