  • Replies 3.6k
Posted Images
There seems to be more mateship between Mark, Homo and Button than anything he has with his team or its members.
Amazing how much you can tell from body language hey, as opposed to PR spin.
Must burn like hell knowing your car that you weren't happy with can win GP's with someone else at the wheel
True that
Well i wasnt sure of Horner and Webber were mucking around with one another...but conference says there is no lost love between Mark and the team management. Dangerous ground for Webber if he pisses too many people in the Red Bull management off, wont matter what the team and mechanics think if Red Bull as a company are going to close in
Can't help but wonder now if Webber will get another caning from his team for 'not giving Vettel enough room'.
Hope he can keep his positive headspace and maintain the consistency.
Vettel meanwhile seems bound to implode with frustration and resentment if he keeps up with his short-fuse dummy spits
Edit: think you and I are thinking the same thing Roy...
yeah I noticed esp. after the sphincter of the universe that Webber appears to talk/congratulate with Hamilton quite a bit and little pats on the back. Don't see the same mateship with Vettel :D
I guess, he renewed the contract with RBR just to stick it to Vettel, I'd bet Webber's aim is to beat Vettel even with some team sabotage, whether or not he wins the race.
I don't reckon they were mucking around, Horner was telling Webber to quit being such a mope and Webber was telling him to blow it out his arse.
Fun times ahead in the RBR team! Mark doesn't give a shit he's signed with RBR for next year if he doesn't get a WDC in these 2 years he never will. I doubt he has the means to get there, personally. Still enjoyed his dominance today though.
The best thing is....Webber leads Vettel in the WDC so puts even more pressure on RBR management when they look for the excuse book for why Vettel should be given any advantage, even down to pit stop strategy and quali order.
I am not confident Webber will be able to ride out this storm if he wants to publicly fight management...but will be fun watching :D I am emailing my mate from Budapest who is working in Ireland...he needs to show me the ropes and will hopefully have a wing man for Hungarian GP or Belgium. Now where do i buy an Aussie flag from :)
interesting video from goodwood recently in light of things. Long but worth the watch, check out 5:25.
See I watch that vid, see how Webber has been tied up with Horner in GP3, how he drove for RBR before Vettel...i cant see them having a bad relationship if Horner was given free reign of the team...i cant help but think Webber knows Horner is up the middle, but Horner has bosses to answer to as well remembering that Horner tried to go it alone by buying Jordan all those years ago but didnt have the budget and only got the call from Red Bull when they took over Jaguar because he had been looking after Red Bull dirvers in Junior categories (i think it was Luiszzi and Dornboos). So Horner is 100% in the pocket of Red Bull as a company, not Red Bull Racing as a racing team.
But, yes, imteresting times ahead. If Webber can get up in Germany and those damn Ferraris finally pull a few points of the Macs then will be interesting to see if RBR implode under the pressure of trying to sculpt history. Personally the more i read about Marko the more he seems to be a destructive force in many things he touches by having to control people and have things only done his way to his liking
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
