I like the latest relevations that not only SV's wing was broken but so was MW's. Allegedly it was repaired and then put on SV's car.
The next bit of stuff is that MW's tub is lighter than SV's one??? Interesting revelation since Luscious Liz was SV's old one....
Who is getting the advantage?? I can't separate spin from fact.
  • Replies 3.6k
Posted Images
Well Mark weighs more then Seb so the team have said several times that they setup their cars in a similar way, have similar driving styles, but Mark is heavier and taller and that poses design problems.
I think all the cars are underweight by quite a margin, but on Marks car they dont get to ballast it up as much as they like
damn it... i thought i attached the blue ones?!
im not a lebo
cant buy the first ones
Similar... rbr pumas.. the rbr logo is a bit different
http://www.eastbay.com/product/model:13798...EYWORD%20SEARCH
and use coupon code EMEBT798 for 20% off which is free shipping here pretty much
Monaco could get the axe? yeah... okay Bernie
I fucking dare you to do it. The publicity would be exactly what your looking for
As much of a challenge it is for the drivers, I'd be glad to see the dinosaur go.. It has no place in the modern game and its been admitted that F1 make a special exception for Monaco and that if they applied for it in the modern day they'd be flatly rejected because of safety. It is a processional bore that offers no excitement and has ended up being little more than a glorified fashion parade and party of the rich and famous.. A true reflection on the repugnant mutant F1 has become..
If you want heritage, then I'd be happy to see F1 stay at Monza, Spa and Silverstone! However, if F1 as a sport was so concerned about heritage and tradition, how could they have gone 3 years without a French GP? Now THAT is a travesty...
Hahahahahaha ... oh, you're serious. Honestly, the guy needs a BS filter strapped to his mouth, but then everyone would wonder where he'd gone because they wouldn't be able to hear him any more.
Lawn tennis is outdated too but no one wants to put the axe into Wimbledon.
Where else can you see Kimi swim out to the 80 footer with bikini clad chicks?
It is all about Kimi's Bitches!
Haha i buy from them all the time.. and actually had the coupon code in clipboard when i saw your post.
Thanks guy. Ill be honest, i saw that site too, but i was undecided on the slight variations of colour
But your 20% nudge, tipped me over the edge... You appealed to the tightass in me!
As of this weekend's German GP, all radio communication between the pit wall and the drivers will be available for broadcasters to air.
Up until now, teams have had the ability to censor their communications, pressing a button that allows them to keep what is said between their drivers and the men on the pit wall away from prying ears.
However, the FIA have taken steps to stop that.
According to Auto, Moto und Sport, motorsport's governing body has taken advantage of a passage in the Sports Act, which states that radio traffic should be made available to all.
However, in a bid to ensure the more colourful drivers keep their swearing to themselves, there will be a short delay between the radio message being said and it being broadcast, allowing FIA race director Charlie Whiting to intervene.
Already, though, concerns have been raised with Mercedes GP team boss Ross Brawn revealing that it won't be long before teams start talking in code, leaving the viewing public with no clue as to what is actually going on.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
