It's not Red Bulls fault that they can design a wing that will generate higher loads in use than the FIA tests for in the static tests, is it?
Nope not at all.. i love it!
good to see fezz now up top to split up jensen and hamos lead..
  • Replies 3.6k
Posted Images
Which of the blondes did you end up smashing?
inni, mini, minee mo...
I stay about 150mtrs from the Singapore GP track, walked around it yesterday ong the awy back from lunch. Air Force was getting some practice in...
Will be an interesting GP. Looks like the race will be at the back of the Top 10 with Button trying to learn how to drive a Mac quick, Kubica, Hamo etc. Expect that Webz and Vetterl will drive off. Even if they stuff up the start, they should just be patient and wait for the first round of stops then blitzt them....when you have over a second in the tank there is no excuse for not getting a 1-2.
Points for the championship could be interesting at end of today. You would have to expect Button to lose out to one, if not both of the RBR drivers, lets see how many points McLaren can salvage.
PS, i dont like the happy Webber. He seems to be at his best when he thiks he is being shafted where he shows steely determination. He seemed to happy yesterday, lets see if he can win happy :)
Rest easy all, I'm here!
Shit reception in the cardboard box!!!
Waiting to see Ze-Tool lunch his start and crowd Capt Chin.
GONZ will swoop Tool and stay behind Webz for the duration.
Schumie to claim bottom step.
On my iPhone so banter tonight may be limited.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
