Actually Garrett and HKS show the "2530" compressor specs as being 63 trim where the GT2860RS is actually 62 .
I once worked out the inducer sizes and looked at factory specs so really many trim sizes are rounded to a whole number .
Regardless the GT2860RS's compressor would be the pick of the bunch and from memory the exducer tips are wider than most/all in that wheel family .
Arguably the HKS turbine housing is best for a 0.64 A/R integral (internal) waste gate type and Garrett don't make a T3 flanged one .
It's possibly acceptable to reprofile an RB25 or VG30 OE BB turbine housing though on an RB20 I'd err towards the RB25 housing .
Sometimes as a mild upgrade people fit RB25 turbos to RB20's but you still have to be mindful of that ceramic turbine and not over speed it .
If you can find a T3 flanged 2530 its probably easiest , they can be rebuilt and the only unique bit is the comp wheel and the profile of the comp housing . If you got a shagged one cheap with an undamaged turbine housing a GT2860RS slots straight in because they use the same turbine wheel . Remember its the turbine housing thats the hard bit to find cheaply .
Options are endless , ask away .
Cheers A .
don't forget that even with a 2530 rb20's dont start pulling till after 4k... no matter what the turbo
your best bet is to get the biggest turbo that is capable of making 15psi between 4000-4500 and then winding plenty of boost into it!!!
after a fair bit of research (and wanting a cheap option) i have gone a hypergear atr28g3 with 0.63 rear and going to screw over 20psi in it :-)
HKS2530s that we did overhaul on, few of them needed to have comp wheel replaced. The only comp wheel in 60mm that fit perfectly into its comp housing profile was a 60mm ex with 48.3mm in wheel. Worked out to be 64.8 Trim matching Garrett T3 3D-1 Comp wheel.
Except they only comes to suit 6.3 shaft which we had to sleeve it and re-drill them out in 6mm to suit the GTRS haft and have bottom of the comp wheel machined shorter to suit the T28BB bearing housing.
We've made .64 T28 turbine housings made with T3x flange and OEM dump pattern made so that’s not a issue.
RB20 is a smaller engine so turbo should be ok to hold 20psi with a 1.6KG actuator.
Yep the bore size and backspacing is usually the drama when fitting bush type compressors onto GT BB cartridges .
If you were a bit concerned about boost threshold there is another cartridge in that family that spec wise looks the same as a GT2860RS but its tip height/width is a little less so it may bring the bost threshold down a little .
There are some mobs around that can build up custom combinations and the generic GT28R would be a good example , all it needs is the std GT28 turbine exchanged for the high performance NS111 76T turbine and you get a 60 trim 60mm comp with the good lightweight low restriction turbine . Its basically what HKS have for the SR20 specific GTSS turbo , its a different spec to the GTR RB26 specific GTSS .
I had GCG build me a hybrid turbo from the smallest BB GT2554R , swapped in that nice NS111 turbine and fitted a reprofiled S15 turbine housing because I wanted the high temp spec material and the deflector vane at the turbines outlet . I'll see if I have a pics .
A .
Edited by discopotato03
Hi guys,
Wanting to strap on some real horses because 158kw isent enough coming from my gts4 and most likely less, I'm Looking at 250awkw and I duno crap about turbos or prices so! i got a quote of $1600 for a ATR43G3 520HP turbocharger with high pressure actuator and braided oil feed line.
I'm looking for criticism and any ideas...input at all with regards to the turbo i got quoted with and if there is any beta options for my gts-4 thanks!
For 250awkw they work well, just remmeber it will need intake and cooler pipe mods (only small) i would buy it or a GT3071R which requires the same mods to fit. Stao was working on bolt up rear housings (i think) as the old versions were v band only. You want to limit boost to 18-19psi NO HIGHER
GT2530 will make 210rwkw on a stocker rb20 @ 17-18psi for more you will need some more work or boost, i have three cars come in reportedly making 220-235rwkw on rb20's and on my dyno they struggled to make 210, im not saying it cant be done but the results ive found require more than just bolting it on for a genuine 230rwkw.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
