semi slicks are not better for the street they are shit
noisy pick every little stone pebble etc up and fling em into your undertray paint etc
and if it rains well good luck
Someone once described em to me on here as sounding like tractor tyres and its quite true
(I drive my car with semis to the local circuit)
Stiff as sidewalls no good for drag at all, great for circuit no good for anything else
Run street tyres for street and get some drag radials on another pair of rims for the drags
and if ya have not got a cage sell the used drag tyres n rims once ya crack 11's
I guess everyone has different experiences. But up until recently I was running Falken RT615 Semis all day every day wet/try. Grip was awesome!!!!
MT's are the one for drags.
The circuit ones are designed to run more tyre pressure so are generally no better than normal road tyres.
The softer compounds found on either mean they last far less kms than a road tyre for the strip.
Driving on the road with some of the circuit style semi's around is actually really good but, it costs you to do it. They grip better, so offer improved safety and on road enjoyment.
Edited by rev210
Thanks for all the feedback and opinions.
I recon I'm going to go with the Federal 595RS's for the rears.
Anybody know where I can get a pair for a decent price?
So you have decided to ignore all the advice that has been offered. Good work. :)
The Federals & Falkens mentioned are an awful choice.
Everyone seems to have there own point of view and I respect them all.
Maybe some are more accurate then others but I already explained I don't want to go a full drag tyre.
So the MT's are not for me. Yes the MT's sound like the best drag tyre set up but I don't want all out drag tyre as previously stated.
Well they were the first set of expensive tyres I've tried so I can't compare to others like re55s.
But they were definitely better than the usual street tyres I've had, once I started getting a bit of camber wear on the front ones (no camber kit on the front of my car) they got rather noisy!
I only used them for street and a couple of skidpan days though.
So what exactly makes a Federal 595RS good for a drag tyre.
The stiff sidewall?
The (relatively) hard compound that doesn't soften when you do your pre run burnout?
What you are looking at is a tyre with the characteristics of an R compound except for the grip. R compounds are pretty hopeless at the drags so one with less grip is even worse.
Toyos what you want :)
The stiff sidewall?
What street legal tyre would you recommend is best for the drags?
What I am saying is stay away from tyres that are supposed to be a half way R compound track tyre. They are a big enough disaster on a circuit but are worse on a quarter mile strip. Those Falkens and Federals are the tyre equivalent of trying to get your missus half pregnant.
If you are not that bothered by times ie won't get a proper drag tyre then just go and get a good road tyre & run that.
But don't be too upset when the times suck.
get a cheap rear tyre that has a taller profile and as soft a compound as you can find. This allows for some sidewall flex (you will be running lower tyre pressures at the drags for this) and the stickier rubber compound will get you more grip.
  • 4 weeks later...
like DSTURBD, im running toyo teo's 235*45*17on the back of mine. very grippy in all weather. i got around the 300 to 330hp mark, i can put it flat in first and wont spin, cost about 220 a tyre so wont break the bank either. haven't got on the drag strip with them yet but will soon (what pressure to run in them DSTURBED for drags???)
Even though the op has probably found some tyres already.. I am running 595RS federals on my car, getting the same 60' and trap as with the hard as buggery, excessively cheap and nasty tyres that I originally had on there. They are nowhere near a semi slick either, treadwear is a lot harder, meant to start slipping on the track a lot earlier as well.
I like them on the street though, stiff sidewall makes it feel a lot more nimble.
If you have a rwd car with decent hp, you can't go past having the proper drag radials, if you want to anywhere on the strip. One set of tyres can't do all tasks.
just thought I'd post my own personal experiences with these 595's.. hope it helps anyone. if not, well..
I have some hoosiers ET drag radials for sale... they are on Ford rims tho they will still fit on your car.. no probs
Hoosiers are 255 and are on a 16" steel rim
They will fit on the stock R33 R32 16" rims also im am selling for $520 ono for 2 tires and 2 rims and they have only done 3 passes down the strip.. there very very new..
these tires sell for over 395each new.. so grab them while there hea.. if you want give me 2 stock rims and ill get a shop to put them on and ill knock the price down to $480
0416740509
Edited by kleicl
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
