Ah cool, I work just across the street at Infinite Networks (its in the building with a reflective front window on a 45 degree angle to the street between Paragon and Kell & Rigby).
From everything I have seen, it doesnt look like a GTR (no flared guards unless im not looking close enough).
Ah, ive seen ur car and thought u worked at kell and rigby. Yeh I told Kesha that i didnt think it was a GTR but she was pretty convinced that it is, I havent had the time to ask her to pop tha hood because i work in a different area to her and dont know her that well yet. But i'll check it out properly one day. Its actually got a series 1 spoiler on it at the moment but i saw it at the summernats before last and it had a gtr wing.
https://www.sau.com.au/forums/topic/30059-spotted/page/153/#findComment-1281071
I'll take a photo on monday and post it up.  :(
Panadl, how come whenever i see you driving around fyshwick your sideways? lol
I saw ur mate filming you one day in tha caldisac off wiluna street, I was in an old white VL 308 Wagon at the time.
HEHEHEHEHEHE sideways never??? yeh i had a video of u also in that beast of a vl. if i find it i will send it to u. So ur the dude that popped around and showed me how to do it lol. should catch up one day when i get my car back :(
https://www.sau.com.au/forums/topic/30059-spotted/page/153/#findComment-1283136
Was that the dark purple GTR with the gold rims and a chick driving?? Seen that around a bit lately.
Cheers
Wheels looked like the stock silver ones. They were definetly 17 inch anyway I think
As far as the driver....10pm and it had real dark tints so your guess is as good as mine :D
https://www.sau.com.au/forums/topic/30059-spotted/page/153/#findComment-1285291
oh i forgot to post on monday i saw shaun going past the front of the transact building i forget what time i think it was lunchish maybe a little later
cool i got spotted, yep that was me going to lunch, got a ****ing parking ticket too.
expensive lunch
https://www.sau.com.au/forums/topic/30059-spotted/page/153/#findComment-1285387
Silver R34 GTR on black TE-37's near Russell Offices at lunch time
about time we had another R32 GTR in town to drool over!
I have to say that Queanbeyan is the import capital! I was at the Thai restaurant a couple of weeks ago, and saw heaps of imports cruising past - skylines, zeds, S13's, S14's an S15, supra etc... I see more imports there than I do in Canberra!
BTW - the restaurant is Lime Leaves and is THE BEST Thai restaurant in Canberra :D (and i have tried quite a few!)
https://www.sau.com.au/forums/topic/30059-spotted/page/153/#findComment-1285447
Stopped p1r4t3r Uh...yesterday...about 5:30pm on drakeford drive... well, saw the car, don't know if it was him driving...no wave was returned
Lol! that's not true! I managed a half assed wave! ;) I spotted you just as you were going past waving, but i was trying to change gears, indicate and steer all at the same time. Got my hand halfway out the window before i realised i was heading for the curb, lol.
https://www.sau.com.au/forums/topic/30059-spotted/page/153/#findComment-1288044
BTW - the restaurant is Lime Leaves and is THE BEST Thai restaurant in Canberra ;)  (and i have tried quite a few!)
where is this so called best Thai place. mmmmmmmmmmmmm :wassup: :wassup: :wassup: :wassup: m yummmmmmmm
https://www.sau.com.au/forums/topic/30059-spotted/page/153/#findComment-1288234
Lol! that's not true! I managed a half assed wave! :cheers: I spotted you just as you were going past waving, but i was trying to change gears, indicate and steer all at the same time. Got my hand halfway out the window before i realised i was heading for the curb, lol.
All good dude :)
https://www.sau.com.au/forums/topic/30059-spotted/page/153/#findComment-1288469
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
