Its a bit harsh laughing at that but i found it amusing, assuming of course no one was serioulsy injured and what not.
He was only a young guy. The lamppost toppled across the road, blocking traffic going one way. Guy gets out of his car and i can't be sure but it looked like he was trying to move it by hand. Pretty funny, but tough luck. looks like he'd been doing something stupid to end up where he was anyways.
https://www.sau.com.au/forums/topic/30059-spotted/page/181/#findComment-1441712
Spotted Jayce today on his moto (nice looking bike) and after him and Erica spotting me and honking to get my attention in the EXACT same place on Tuesday, this is getting wierd... Jayce are you stalking me, or is it the other way round????:P
https://www.sau.com.au/forums/topic/30059-spotted/page/181/#findComment-1441832
Lol i know how he feels, i waved at a few 'lines today and got waves in return but i cant for the life of me remember who or where lol.
Well, I think you might have waved at me out Gordon way sometime today, but my memories not much better.
No idea why...... :alcoholic
https://www.sau.com.au/forums/topic/30059-spotted/page/181/#findComment-1444372
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
